Cb radio
Antenna & install follow up:
87 Ranger: I said before, I use a piece of flat plastic to stabilize the whip. In this instance, it’s a piece of 1/8 inch aluminum diamond plate. It’s folded 90° to the inside of the bed, and that’s where it’s screwed into the bed top. I split a small piece of rubber tubing, and put it over the edge, to keep the antenna from grounding out. There are two holes drilled out near that, with a zip tie in a loop. The loop is actually inside the antenna, with just a tiny little break away red zip tie holding it to the loop.
That’s my master technician partially in the picture to the right.
F250: less elegant, but I have a long zip tie looped around the bracket that holds the cap down inside, and again a small zip tie on that to hold the antenna from wobbling
97 Ranger, the antennas: Note the base-loaded whip. That’s for the small radio down by the brake control. You can’t have both on at once or when you key one, it’ll blow your eardrums out from the other. I learned that.
I get a lot of folks asking me where I bought the antennas with the alternating red and white bands on the top. They came from my antenna junk pile accumulated over the years in the shed of miracles.
I painted them with white rustoleum and then with red rustoleum, simply masking out the lines on top. You can paint the fiberglass antennas any color you want, as long as the paint does not have any metallic component (like a silver or bronze metallic).
I mounted them behind the cab a little below the door handles. Only one is connected, but the transmission is still deficient. Asking around and reading stuff, it was pointed out that the headache rack on the truck is aluminum, and due to conductivity and the design, that will interfere with the signal even more than just the sheet metal of the cab. I’m planning on redoing them, but I haven’t figured out exactly how yet. There are other modifications that take priority on the “Road Ranger” for the 2026 season….
Here’s the final on the Cobra 129LTD Classic set up, The beaded chain is a tug for the air horns. Note, also the little aluminum strap that helps hold the assembly up. I made that, and it runs up over the clip that holds the sunvisor in the center, due to the weight.
For the temp GE, I made an L-shaped plate that tilts backwards, and I secured it underneath the plastic center shroud that holds the drink holders and the stick shift boot, and mounted my brake control on that. I don’t like them under the dashboard or somewhere else, and by making this custom mount, it’s right at my fingertips while my hand is on the shift if I have to hit the trailer brakes. Since it’s a temporary, I just zip tied the GE radio on the other side of that plate. The mic just sits on the hump in the little hole that’s left.
And I have to do a big, giant shout out to @sgtsandman, and another buddy in the ham radio shop near me. I really don’t know a whole lot about these other than what I’ve tinkered with over the years, certainly when it comes to how the antennas work best. He’s the guru for TRS, and he pointed me to a lot of what I’ve done and what I’m going to do. And again, I always talk to the local shops before I do something crazy. Anybody who works in a CB or ham radio shop isn’t doing it for the pay, they’re doing it because they love playing with the radios, so they’re always a good source of help.
Again, just conversation
And finally, the CB junk pile in the shed of miracles.
I’m going to swap these two for the radios that are currently in the 87 and 97. Then I’m sending those to the CB shop to get tuned up. I like them with the front mount mics for overhead, and left side mics for under the dash or the hump.
Also on the shelf:
A couple radar detectors over some small radios with a pile of microphones and some walkie-talkies on the left. The two 479s are on cigarette lighter plugs, and I have the little magnet antennas for when I’m following somebody or vice versa. Very good little radios.
Spare cobras and others. The Uniden is a great little radio, but I’m not sure if any of my mics will fit, and I don’t want to burn it up with a cross wired mic. And a third Cobra 148 GTL. And the big Realistic has some mods and switches on the side that were added, but I’m not sure exactly what they do. It’ll go to the radio shop when I send the two in the trucks. I think I’m going to use that one for the 87 town car if it checks out OK.
And the rest. The 23 channel Sears Road Talker single side band is as big as a Volkswagen, but it will look proportionally correct on the hump of the Marc V. I have to replace the Mike outlet, a task for down the road.
I think there’re a couple more, but I couldn’t find them quickly.
You buying? lol, yeah, it will probably be a Cobra when I get around to it. Money is currently a critical problem.
The Cobra is a good choice. I've seen good reviews on the Uniden CMX760. I have the Midland 75-822. The speaker quality is horrible but it performs well otherwise. The bonus with the Midland is it can be used as a mobile radio or as an HT. The Midland is the least expensive of the three with Uniden right in the middle. I've had good luck with Uniden in the past. Of course, Cobra is one of the top brands when it comes to CB.
Well guys got the cb in an my antenna on I’m not sure people can hear me? I don’t know I never get a response back
There might not be anyone on at the time. Truckers that still have CBs don't haven them on all the time like they used to or they are just ignoring it.
As far as range, there are a lot of factors involved. Antenna setup, terrain, and atmospheric conditions. The general rule of thumb for most vehicle systems is about 2 to 8 miles of range. If you are on a ridge or hill top, your range will be greater since there is less things blocking your signal. If you are in a valley, your range is going to be less. CB frequencies will "bend" over hills and mountains to an extent but don't expect a lot from that. Atmospheric conditions, can greatly effect your range. It can reduce your range or it can greatly increase it. Then there are conditions that cause a thing called skip. That can really boost your range BUT when you are skip, those relativly close by you may not be able to hear you ar all because the signal skips right over them. Those within, say a mile, may still be able to hear you but after that, until the radio waves come back down to earth, people won't hear you.
Can I hook a ham right into my truck cb antenna or what special things do I need? Is it worth it? I guess
No, different frequencies. So, will require a different antenna. That is why my 2011 has four antennas, not including the factory radio antenna, and the 2019 has three. Radio can bue fun but like any other hobby, it gets epensive fast.
Also on the shelf:
@sgtsandman
Do you have any idea what those two little switches on the side of that big realistic radio might be? And how I would test what they might do?
Cobra, Uniden and Midland are the only ones I’d really consider these days for any radio. CB, GMRS, whatever.
I do have three RadioShack CBs, two are the “paperback” style and one is a full size. I bought the little ones on sale new and was given the big one. Also have an old Pace 24 channel that dad gave me and the Cobra I got with the Choptop. Supposedly, everything has been tuned and peaked except the “paperbacks”. Well, the Pace I’m certain has been worked on because I gave it to a CB group to fix up for me. The others I was told were done.
I used to know a lot more than I remember currently about CBs, used to be really into it and had done a lot of research and stuff. I knew the 102” whips were the ideal but didn’t buy them until I learned my lesson the hard way.
@sgtsandman
Probably some aftermarket mod. Maybe an amp or something. Definitely not original equipment.
Yes, I know it’s aftermarket, but I have no idea what they actually do. So I’m looking for a little guidance on how I would check it out without spending money. I do have a test bench and get broadcast from that bench.
Open up the case and see what it is connected to. Post a picture.
@sgtsandman
Not a clue. Pictures might help. If it's aftermarket, you might have to take it to a shop and hope the person at the counter has some experience.
Thank you for all that info I just learned alot
