- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
Wait, both shifter housings are in first but you're stabbing the shifter in the neutral location because the side pressure spring deal won't let you get the shifter in the first location, you might need to pry that pushrod deal over to get the shifter in there before the detents will release to let you move it? never taken that part apart since it's complicated and nothing generally wears out... That's likely your problem, you need to get the shifter into the gear the assembly is in...
And this here is the exact reason you only pull the shifter out in neutral! There's ball bearings that limit the shifter so it physically will not go into more than one gear.
