A couple comments/questions:
1) on regular D2/ULSD a tdi has no issues going out to 500k without compression loss. I have several customers in the +450k miles range with ZERO loss in compression (450psi). There are a few members over on tdiclub with +600k miles.
2) I'm not that well versed with the idi injectors on your PSD...what are the pop pressures for those injectors? I'm guessing they are single stage injectors?
500k? outstanding for an expectation!!!
i would think 250 300 would be pushing it at 30 percent though. only one way to find out
my psd is just shy of 900k, original almost everything. i have never been more impressed with an engine than those.
its unit injector, and in my e350. those injectors are "supposed" to be replaced about 200-250k intervals according to most...bout 1200 bux to do it cheap..it runs rough but does fine at cruise still....its getting hot so i think they are dripping now. so its getting retired.
the idi in my ranger is a 6.5, based on the detroit diesel built 6.2 that gm used. it is on the way to 450 k miles which for those is a miracle....
...it weighs 720 pounds complete and is a v8, so they are
light duty to say the least. for 70's technology and design they are very good engines to 200 hp.
those injectors are a single stage as i understand it, poppet style. i have a vw line and adapter to make my pop tester to crank them up, basically its the same type of injector as the idi vw from what i understand. so i was hoping you were an expert with them...
keep me from bungling around in the dark longer then necessary
i figure by the time you get this little guy proved out, i will have some solid data for ya and let you use some stuff if you want to experiment.
i need to drive yours to see if its something i want to do...
so hurry tha fawg up
