bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS 25th Anniversary
Ugly Truck of Month
TRS Banner 2012-2015
- Aug 9, 2007
- woodhaven mi
- Automatic
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
Or you could just get a low hour reefer take out for under 1000.00 add a turbo, and see high 30's easy. they are di all mechanical and plentiful. One of my friends has the Yanmar 2.1 and I have the Kubota 2.2. His in a 2001 4x4 s/c and see's high 30's all the time. He has a build over on 4bt.com.
well, i would like to see some 0-60 times with those. if it pulls a 10 or less 60 mph then i will likely go that way. is the glut of non cali compliant reefers over or are they still easy to find at good prices??
35-4500 would put you at about 3-350rwhp on a 6.5 w/ ATT or HX40II and a built FTB modded 4911 pump; I can't see that getting that much less mpg with plenty of TQ and HP to motivate down the hwy...
Sent from my T-Mobile Galaxy S2 using Tapatalk 2
i wish not to derail this thread, and i hope this discussion enhances it....
i have secondary fueling motivations, which is important and you guys likely dont realize that.. it drives my willingness to dick around with easy to get di setups and mechanical injection.
drag, that engine setup you describe in a regular supercab ranger would be killer i agree.
it possibly would exceed 25 mpg hiway i would wager consistantly 23-25 at 70 mph even...stock tires and corrected gearing.
reliable over the long term...no way. anything over 250 hp at the wheels in those easy to get 90's engine has proven a tiresome waste of time from what i have seen. i run allot of hard miles, way above average.
the later and current engines on the other hand are definitely a huge improvement but costs are still out of hand for living with the restrictions of idi in both economy and reliable power/cold start. i was working a deal to get a brand new one sans injection and manifolds for 3800, but i was injured back in feb and all my money saved for the truck updating is going to living expenses. cranking up one of the units i have currently past 225-250 is not what i will do....when travelling across the country to go to work getting there is important. n/a its been nothing but reliable...and slower then smoke off shit.
the good with them is ability to burn different fuels.
for my bronco 2 i can freshen a later 1.9 and mechanically inject it with cranked up injectors and burn multi fuels as well. i am sure greengeeker knows that is my intent for the trouble to do that.
burning crap fuels in commonrails is a no-no, so i am limited there.
if i ever decide i want 400 hp at the wheels, i will mechanically inject a duramax, the prices for those has come down to my range...right now i know where a sub 100k unit is for 3500 with all of the wiring and would drop right in my ranger....
the ranger needs a big engine, the b2 can get by with the 4 banger.
