Vehicle Make / Model: Model Year(s):
- FORD / BRONCO II 1986
- FORD / RANGER 1986
Manufacturer: FORD MOTOR COMPANY
Report Receipt Date: SEP 24, 1985
NHTSA CAMPAIGN ID Number: 85V116000 NHTSA Action Number: N/A
Component: ELECTRICAL SYSTEM: WIRING: FRONT UNDERHOOD
Potential Number of Units Affected: 7,886
Summary:
THE ELECTRONIC ENGINE CONTROL WIRING HARNESS INSULATION MAY BE DAMAGED DUE TO COPPER SPIKES PRODUCED DURING THE WELDING OF ITS WIRES. THIS CREATES A POTENTIAL FOR A SHORT CIRCUIT BETWEEN THE WIRES WHICH ENERGIZE THE FUEL PUMP, CAUSING SOME FUEL INJECTORS TO OPEN, DISCHARGING FUEL INTO THE ENGINE. CONSEQUENCE OF DEFECT: FUEL DISCHARGED INTO THE ENGINE WOULD EVENTUALLY LEAK THROUGH THE EXHAUST SYSTEM TO THE GROUND. THIS COULD RESULT IN A FIRE IF A SOURCE OF IGNITION IS PRESENT.
Consequence:
SEE ABOVE.
Remedy:
REPAIR WIRING HARNESS, CHECK ENGINE AND CATALYST FOR DAMAGE.
Notes:
VEHICLE DESCRIPTION: LIGHT TRUCKS EQUIPPED WITH 2.9 LITER ENGINE. SYSTEM: ELECTRONIC ENGINE CONTROL WIRING HARNESS.
About The Author
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford Ranger off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
