Introduction
Choosing the right lift height and tire size for a Ford Bronco II can be confusing, especially when real-world fitment often depends on more than just suspension height. Fender trimming, body lifts, wheel backspacing, suspension design, and even axle swaps all play a role in what tire sizes will actually fit and function.
This Ford Bronco II lift and tire size comparison guide provides real-world photo examples of Broncos running everything from stock suspension to solid axle swaps, with tire sizes ranging from factory dimensions up to 37-inch tires. Each example lists the suspension lift, body lift (if equipped), and tire size to give you a clear visual reference of what different setups look like in practice.
Whether you are planning a mild daily-driver build, a trail-ready weekend rig, or a fully built off-road Bronco II, this page is designed to help you compare lift heights and tire sizes side by side so you can make informed decisions before cutting fenders or ordering parts.
Note: The stock Ford Bronco II tire size is 205/75R15 (approximately 27.1 inches tall). Larger tires shown below may require suspension lifts, body lifts, fender trimming, aftermarket flares, or drivetrain modifications depending on the setup.
General Guideline
For years this has been the general guideline that people have followed when deciding how much lift is needed for a tire to fit, or what size tire they can fit with the lift they have. The examples that follow below this chart are probably a better representation.
Bronco II Tire Size
Lift Height 30″ Tires 31″ Tires 32″ Tires 33″ Tires 35″ Tires
2-Inches Fender Trimming 3″ Body Lift
3″ Body Lift
Fender Trimming
N/A N/A
4-Inches Yes Yes Fender Trimming 3″ Body Lift
3″ Body Lift
Fender Trimming
6-Inches Yes Yes Yes Yes 3″ Body Lift
28-30-Inch Tires
Ford Bronco II With 1.5-Inch Front Coil Springs, 1.5-inch Rear Add-a-Leaf, 235/75/15 (28.9" x 9.3" x 15") Tires
1.5-Inch Front Coil Springs, 1.5-inch Rear Add-a-Leaf, 235/75/15 (28.9″ x 9.3″ x 15″) Tires
Ford Bronco II With 4-Inch Skyjacker Suspension Lift With 245/75/16 (30.47" x 9.65" x 16") Tires
4-Inch Skyjacker Suspension Lift With 245/75/16 (30.47″ x 9.65″ x 16″) Tires
31-Inch Tires
Ford Bronco II with 31x10.5R15 BFGoodrich Mud Terrain TA KM2 tires
31×10.5R15 Tires With No Lift and Trimmed Fenders
Ford Bronco II With 2-Inch Lift With 31x10.5x15 Tires
 2-Inch Lift With 31×10.5×15 Tires
Ford Bronco II With James Duff 3-Inch Lift & 31x10.50x15 Tires
James Duff 3-Inch Lift & 31×10.50×15 Tires
Ford Bronco II With 3-Inch Suspension Lift, 2-Inch Body Lift, and 31-Inch Tires
4-Inch Suspension Lift and 31-Inch Tires
32-Inch Tires
Ford Bronco II With 1.5-inch Lift with 32x11.5x15 Tires and Bottom Rear Corner of The Front Fender Trimmed
1.5-inch Lift with 32×11.5×15 Tires and Bottom Rear Corner of The Front Fender Trimmed
Ford Bronco II 4-Inch Suspension Lift With 32x11.50Rx15 Tires
4-Inch Suspension Lift With 32×11.50Rx15 Tires
Ford Bronco II With 4-Inch Skyjacker Suspension Lift with 32-Inch Tires
33-Inch Tires
This Bronco II has a 4-inch Skyjacker suspension lift with 33x12.50x15 Interco TRXUS MT tires
4-Inch Skyjacker Suspension Lift With 33×12.50×15 Tires
Ford Bronco II With 3-Inch Body Lift, Cutout Fender Flares, and 33-Inch Tires
Ford Bronco II With 4-Inch Suspension Lift, Bushwacker Cut Out Fender Flares, 33-Inch Tires
Ford Bronco II With Solid Axle Swap, 6-Inch Suspension Lift, Trimmed Fenders, 33-Inch Tires
Ford Bronco II With 4-Inch Suspension Lift, 2-Inch Body Lift, and 33x12.50x15 Tires
4-Inch Suspension Lift, 2-Inch Body Lift, and 33×12.50×15 Tires
Ford Bronco II With 4-Inch Suspension Lift, 3-Inch Body Lift, and 33-Inch Tires (33x14x15 Rear)
35-Inch Tires
Ford Bronco II With 6-Inch Suspension Lift, 2-inch Body Lift, Cutout Fender Flares, and 35-Inch Tires
Ford Bronco II With 4-Inch Suspension Lift, 3-Inch Body Lift, Bushwacker Cut Out Fender Flares, 35-Inch Tires
Ford Bronco II WIth Solid Axle Swap, 5-Inch Lift, Heavily Trimmed Fenders, and 35-Inch Tires
Ford Bronco II With Solid Axle Swap, 7-Inch Lift, Trimmed Fenders, and 35-Inch Tires
Ford Bronco II With 5.5-Inch Superlift Lift, Cutout Fender Flares, and 35-Inch Tires
Ford Bronco II With 5.5-Inch James Duff Lift, 2-Inch Body Lift, Cutout Fender Flares, and 35-Inch Tires
Ford Bronco II With 3.5-Inch Suspension Lift, 2-Inch Body Lift, Cutout Fender Flares, and 35-Inch Tires
Ford Bronco II With 3-Inch Suspension Lift, 2-Inch Body Lift, Trimmed Fenders, Pacer Fender Flares, and 35-Inch Tires
Ford Bronco II With Solid Axle Swap, 6-Inch Suspension Lift, Cutout Fender Flares, and 3-Inch Tires
Solid Axle Swap, 6-Inch Suspension Lift, Cutout Fender Flares, and 35-Inch Tires
37-Inch Tires
Ford Bronco II With Solid Axle Swap, 6-Inch Lift, 2-Inch Body Lift, Trimmed Fenders, 37-Inch Tires
Related Articles
Ford Bronco II Specifications & Facts
Ford Bronco II Common Upgrades
Overlanding A Ford Bronco II
Ford Bronco II Builders Guide
About The Author
