Put in new hood bumpers and plug wires on the ‘07 2.3 w/ 170k. Discovered oil in the plug wells. Could be CHT sensor leaking or more likely valve cover gaskets. Ordered the 19mm deep well socket for the CHT sensor.
The last time I had that, it was the donuts for the sparkplug tubes. OEM or Felpro were the only ones I could trust.
Got a Fel Pro valve cover gaskets on order. I’m unsure what you mean by spark plug tube donuts?
It was a Honda CR-V. On their engines, the spark plug tubes have their own gaskets because the spark plugs come in through the valve cover between the dual over head cams. The 2.3 Ecoboost is a similar setup.
In any case, it sounds like you have a valve cover seal problem, even if you have your spark plugs on the side of the head instead of on top.
Oh. On this duratech, the valve cover is on top surrounding the vertical spark plug wells, so it almost has to be the valve cover gasket(s).
Thanks.
I finished installing my torque monster headers and built my exhaust system, the truck sounds awesome.
I've been chasing a weird issue where my turn signals hyper flash when I'm stepping on the brakes, I finally found the issue and it was a couple of wires above the spare tire carrier that had been chewed up by packrats. I soldered in new wires and fixed that problem. I can't begin to describe how much I hate packrats!
