4.0 into 89 Bii crank no start help me pls.
Westminster
CO - USA
Other
Toyota sienna
Vehicle
Ford Bronco II
Drive
Stock
Stock
Helping friend with his b2 engine swap. I’m getting crank but no start. After a little figuring out, the fuel pump was bad so I just replaced the fuel pump. We are now having gas to the engine for sure but it’s still only cranking and not starting. When spraying starting fluid in it turns over but doesn’t stay started. Do I need to check the injectors?See if they’re getting fuel. And then trace it to a wiring problem possibly I don’t know I’m stuck. it’s a 92 4.0 I think maybe late 91. Into an 89 bronco and he said it had fuel injection. But if the computer is getting power that controls the injectors doesn’t it and that’s all 4.0 wiring stuff nothing that I would need to splice. Maybe camshaft position sensor or another sensor. I’m not sure. Can somebody please help.
Figured it out finally. It wasn’t a wiring or sensor or grounding issue. After testing the icm it seemed to be at fault got a re manufactured one for a measly 250$ to have it right away. Only to be disappointed when it didn’t solve the issue and tested the same as original. (Have an extra if anyone needs one I’ll sell it cheap). My issue was the mechanic before spliced the fuel lines properly but connected them backwards! Fired right up when the fuel lines are connected correctly. Thanks for the previous suggestions and advice I’ll post some pictures once I have under the hood looking decent.
I did the same when I first swapped my 4.0. I thought for sure I'd broken the regulator by trying to pump through it backwards...
