- Feb 13, 2025
- Age
- 53
- Kansas
- 3.0 V6
- Automatic
- Tire Size
- 225/70/15
Starting a "build" thread that is more of a maintenance thread for a "low" mileage neglected truck.
Details: 2001 RWD XLT Flareside Supercab with the 3.0 flex-fuel and 5R44E
Just picked up this 2001 Ranger. Body and interior are in amazing shape. It has 101k and wasn't loved much. Towed it home 3 hours because the tires are 12 years old. My Superduty made easy work out of the tow. I may daily it a year or 2 as it's for my 13 year old son as his first vehicle.
Items replaced so far due to a VERY rough idle, stalling, failing to start at times, transmission that runs better with O/D off and worn out bushings all over:
2/25/2025 @ 101,756 miles
Transmission fluid and filter - Wix filter & gasket and Motorcraft Mercon V fluid
IAC - Hitachi
Coil, sparkplugs, plug wires - all Motorcraft
Cleaned MAF and Throttle body - removed throttle body for this
Swaybar links and sway bar bushings - Moog
Cam position sensor and Cam Synchronizer - Motorcraft
Air Filter - Wix
Fuel filter - Wix
Oil and filter - Pennzoil full synthetic 5W20 high mileage and Motorcraft filter
2/26/2025
Driver door switch - Motorcraft
Philips Ultinon 9007 led bulbs
Silverstar 3157 front turn signals
2/28/2025
PCV - Standard Ignition
3/2/2025
Coolant flush, new thermostat and temp sensor, both Motorcraft, Prestone antifreeze
Both upstream O2 sensors -Bosch
Programmed 2nd key using forscan, Batteries Plus cut it for $11. Strattec Key was used.
3/9/2025
KYB Excel-G shocks for front and rear
Upper control arms - Carquest premium
Lower ball joints - Moog
MAF- Blue Streak
EGR pressure sensor- Standard Ignition
To order/do:
Brake rotors and pads, not sure what brand just yet
Lubelocker gasket and rear diff fluid
New set of tires
Rust Reformer the frame and undercoat it (fluid film or PB blaster surface shield)
Gifts (eventually for my son to add to the truck, this will happen over the next 2 years)
Touch screen head unit with Apple Carplay & Android auto
4 new speakers
Window tint
Floormats
Tonneau cover
Exhaust tip
Windshield wipers, lol
The truck needs a deep clean on the exterior and the interior will be a breeze, I love to detail/clean my vehicles, but this is very clean as it sits. Already removed and cleaned the armrest, it looks new now. I'll try and do better with more pics in the future!
IAC - Hitachi
Air Filter - Wix
Fuel filter - Wix
2/26/2025
2/28/2025
3/2/2025
3/9/2025
MAF- Blue Streak
To order/do:
New set of tires
4 new speakers
Window tint
Floormats
Tonneau cover
Exhaust tip
