Radio only works in park
al704
Altoona PA
4.0L
07 fx4, auto trans radio has no sound with transmission in gear, works fine in park. Radio has power no sound. Any ideas??
Stock radio or aftermarket? Stock speakers or aftermarket?
A few other questions:
  1. Are you the original owner?
  2. Have you ever had to modify the wiring?
  3. Has it sat for long enough to get mouse damage?
  4. Is the radio fully functional when in park?
  5. Have you removed the radio to check the condition of the harness?
Not original owner, no wiring mods, rarely driven I suppose mouse is possible, fully functional in park, have not attempted to troubleshoot yet
Have you tried swearing at it?
Maybe a solid punch in the nose would help...
Strange symptom indeed. I would drop the knee bolster under the column and do a bit of wiggle testing of harness and connections.
I have 06 diagrams... if you get to a place that they might help.
gotta be a short somewhere.
assume column shift?
if you wiggle the shifter while it's in drive, does the sound come back intermittantly?
Try the blower and other pieces in the dash. If some of them have the same problem, I would suspect a grounding problem to the dash.
I agree with checking grounds.
Have you tried every position of the gear selector?
Have you tried using the radio when outside of a park ?
Did the Ranger ever have anything like mute in Reverse?
