OEM+ radio build, 2008 standard cab
Li'l Work Truck
Did you turn it off and back on again?
Pendleton
SC - USA
Vehicle
Drive
2.3L
235/70 R15
Complacency is the key by which tyranny opens many doors.
I've been putting a lot of thought into my truck lately, specifically about the audio system. Right now it doesn't have one. The previous owner did the right thing and put an aftermarket stereo in using harness adapters and not slicing up the wiring, but the install wasn't very solid and it rattled going down the road so I ripped that piece of crap out - I mean, professionally uninstalled it, and have been riding in silence ever since, which is when the thinking started. I like the silence. No ads. No invasiveness. Just time driving the truck, and at night there's a warm glow from the climate control lighting in the double-DIN-size hole that I've pretty much chosen to leave open until I figure something out.
I had an idea to forgo the head unit entirely and mount a blank panel in the radio spot, then put a magnetic phone holder there. That way, I could mount the phone in landscape mode and use it for maps. Well, that got me thinking, "what if the phone was my head unit?" I only use the phone anyway, and if I want terrestrial radio, there's a few apps for that. However...
I don't remember who it was that got them, but somebody here bought some OEM Lincoln radios, I think. Either way, they didn't have speaker out, just line out, and that got me thinking: "why not integrate an OEM Ford radio with just preamp out," so I started cruising the 'Bay. Some late 2000's Audiophile and Shaker 500 systems as well as most of the Fusion radios were externally amplified, and all three systems had integrated aux ports - the most important part. Used units with clipped harnesses are available.
Disclaimer: If you are an audio purist, now's your chance to walk away.
I have a SoundStormLabs SSL8 all-in-one under seat subwoofer that I pulled out of my Festiva, and online I found a set of Jensen 6x8" speakers with a 2-channel, 200w Jensen amp for about $115. I've seen multiple conversations about the rear speakers in the standard cab, which I have interpreted to mean are mostly a waste of time due to their low position and firing angle, so this will be a 2.1 setup.
The sub will not fit under the seat, nor do I want to lose precious wubs, so the AIO will be oriented vertically and centrally on a carpeted MDF panel on the back wall so it will fire between the seats like a sports car system (Fiero, Corvette, Viper, etc.) The SSL logo will be replaced with the Ranger badge from the tailgate. I have other plans for that. I've also got two pairs of silk neodymium tweeters, one pair of which will live in the sail panels in the doors, as long as they don't interfere with the window air vents in the dash. The speaker location in the doors should be high enough to actually stage fairly well with the tweeters. EDIT: Changed my mind. See below.
The phone is still going to be the primary input device, but I like the thought of an OEM+ appearance. I'll run the phone through an OTG DAC which will give me USB-C connectivity and PD charging via a buck converter powered by one of the 12v sockets I removed from the radio bezel, while adapting from USB to 3.5mm and again into the wired rear AUX harness of the head unit. At this point I should probably mention that I do not want Bluetooth.
The under-dash tray is the perfect location for relocating the 12v sockets, though my plan is to 3D print a replacement for the tray that fills in the area. That's not necessarily a part of this project, so I'll start a thread on that later. The reason I mentioned it, though, is because I am about to have three holes in my radio bezel. My version of the panel has two 12v sockets and a passenger airbag warning light. All 3 spots are going to be repurposed as switches, because the 12v socket locations "fit" 22mm switches, as long as you have the plastic insert ring.
The warning light will be relocated to the 3D-printed panel. The left 12v hole will be populated by a green, illuminated switch with a speaker indicator to enable/disable the subwoofer. The truck doesn't have fog lights but it does have a brush guard that will get some lights, so following Ford's weird layout, the right side 12v socket is getting a blue LED switch to indicate bumper lights. I need to measure the hole left after removing the passenger air bag light, but I'm mounting a set of Nilight backup lights to a hitch bracket I bought, and that smaller hole will house that light switch.
All in all, I hope to build a system that I can use CD's, AM/FM, and any media player I want, all while looking mostly stock. More to come as parts arrive. I'll throw some reference pics up soon.
I like the sound of it so far. Really wanna see the finished project.
Found a Shaker 500 radio tonight. Hopefully it'll be in my possession in a few days.
Here's an AI mockup of the final concept.
AI mockup of the lower cubby, populated with a power charging panel.
More AI, this time tweeter placement. Likely these will be 3D printed. Full door and close-up. I'll try to get the subwoofer mock up images soon.
Subwoofer, and AI badge replacement mock-up:
Well, they wanted premiemiemium money for OEM Shaker 500 radios, especially since the CD changer assembly in most of them has failed (belts, nylon gears, and hardened grease) after 15 or so years...
⚠️WARNING! INCOMING RANT: 📢 I have car stereos from 40 years ago, blah blah blah, newer radios are blah blah blah, something something planned obsolescence...
⚠️WARNING! RANT IS OVER.
However, apparently the Audiophile units from the Fusion are made of a lesser Unobtanium alloy known as Gimmium, so I bought one from eBay that only cost a kneecap and an elbow. It doesn't say a cool thing on it, but it does have chrome "trim rings" on it that match the chrome subwoofer grille ring, and I suppose I could get some chrome chrome paint for the trim around the tweeters...
These pictures were modified with AI.
I know I'm going to have to recondition the internals anyway, so I'll use a different lubricant (Super Lube Synthetic 21030) and replace the belt. That should quieten things down and give me 6 discs worth of MP3's in the dash. I'm wiring it up with a Metra 71-5520-1 reverse harness.
The radio is on its way to me now.
I built a pretty nice system in my 98 using the factory head unit. I went real simple. I used a line level converter feeding a 5 channel amp. I replaced the fronts with some 6.5" Kicker components with 1" tweeters. I just drilled the door panels above the door speakers for the tweeters. I had some pioneer 6x8s in the rear ran full range. It was extended cab. I built a down firing box as a rear middle console. Held 1 10" JL audio. But I didn't use any of the factory channels off the radio except to need the line level converter. Sounded great. That was before our phones were mini computers. I also had a 400 CD case I hauled around. Still better than the multiple cassette cases flying around the cab haha
NVX XPLOC4 4-channel converter and Metra 71-5520-1 reverse harness purchased and waiting. The XPLOC4 is likely overkill, considering its 600w max input. I just needed a wire to RCA conversion. Need to test the audio output of the RCA to see if it even picks up the ~1.7w of output from the Fusion radio. Got some wires and ferrules coming soon, too.
I'm pretty much fine with a 400-CD collection, albeit digitized. I remember the heat getting to some of my old cassettes. Interesting sounds came from heat-distorted tapes! 🤣
And the nice slur they gain on your favorite tune haha. I had a Pioneer Super Tuner 2. It had an auto repeat function on the tape deck. I wore out a couple songs back in my high school days. Haha. Whichever ones had the most bang haha
Just got the NVX XIX43 4-channel RCA cable and ferrule kit in. Next up is the NVX XFDBU2 fused distribution block. I'm still waiting on the OFC 14/4 National audiophile speaker wire to run from the speaker amp back up to the front speakers through the harness. Lots of movement right now. Mostly my money moving out while parts move in.
  • OEM+ radio build, 2008 standard cab
And because I'm pretty much sharing everything, here's a picture of wire.
