I'm hoping @Uncle Gump, @lil_Blue_Ford, @RobbieD and some of the other folks who have been REAL helpful can weigh in on this one...
I ordered a factory/OEM styled radiator (not Motorcraft) to see if there was going to be anything different from the Alloy Works one(s) that haven't been up to task seemingly. I was mostly concerned with the angle of the upper radiator outlet in particular.
Initially it didn't appear different to me which frankly got me a lil agitated. When I was begrudgingly in the process of packing it up to send it back to Parts Geek I noticed that it looked significantly thicker than the Alloy Works ones. Measuring confirmed that the Alloy Works were 1.75-inches thick, and the OEM-style was 2.25-inches. That massive difference got me thinking that was the reason why the cooling couldn't keep up.
So, along with a variety of hoses for my BII and later model 4.0 Exploders, a 180-degree thermostat and new radiator cap I decided to swap them out yesterday. I had to remove the universal fan shroud and bought an zip-tie style oil cooler installation kit to mount it to the new radiator...which I didn't get exactly right since the fan blades will now strike if I hit I hard enough bump but that's easy enough to rectify...
I expected it to run cooler with the new (lower) thermostat and it did. It took quite a bit longer for it to reach operating temp too which pleasantly surprised me too. Mind you I'm using the idiot gauge which while isn't as accurate as an aftermarket gauge like an AutoMeter which displays the actual temp, is better than nothing and is at least a constant in my observations.
I started driving it around near my house, just in case anything went sideways. Temp was peak for the day at 106 so it was definitely toasty. Speeds varied but didn't exceed 45 and I had a few stop signs and lights to deal with and then did some slow (admittedly perhaps creepy) driving through some residential areas. Temperature barely increased, but did to the point it was noticeable and the needle was just above the horizontal/level position on the gauge.
At this point I'm thinking (with the exception of my botched fan install and the occasional noise) that I have it handled, but I had one final test in mind. I let it sit and idle for about 10 minutes or so while playing musical vehicles, etc. and that's when the "resting" temperature started to rise. It didn't technically overheat and exceed the normal range but was right up at the N/O which is significantly elevated.
I was disappointed and didn't think this was acceptable. I understand these engines "run hot" but with the work I've done I expected to be done with it after getting the OEM-style radiator in there (which fit the hoses I swapped over MUCH better than the Alloy works).
This leaves me thinking...water pump maybe? I'm curious what y'all think, it's literally the only thing (with the exception of the heater core/hoses) in the cooling system that hasn't been replaced and it's a straightforward enough job, I just wondering if I go through the hassle of it if it's going to result in lower operating temperatures...
Thanks all!
Thanks all!
