lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
I will say this… my Choptop, back when I first lifted it to a 3” suspension lift and 2” body lift on 33x12.5-15 tires, it was tolerable. I had a set of 31x10.50-15s that I wanted to wear out so I swapped those on once. Made it to the end of the street and turned around, it was scary tippy. The little bit wider tires kept it planted waaay better. It’s still my big spring toy, but the wide tires gave a lot of stability… even though I only run 10-15 psi in them.
