Chopped Top B2 on Wagoneer chassis
crisd
5+ Year Member
I've set a Bronco II on a shortened Wagoneer chassis. Also, cut the top off the rear and welded on a Ranger rear. Does anyone care to read how I did it? Here are some random pics during the build.
Sure!
Kind of amusing, there is a channel on youtube I kinda follow where they grafted the front of a TTB F-150 frame onto a Wagoneer frame (with the wagoneer body still on it)
Yep, I'm always interested in swaps.
I wasn't sure if anyone was interested in a cut up Bronco II on a Jeep chassis since it's kind of Frankenstein. So a little back ground... I wanted to upgrade my Wagoneer's three speed automatic to a five speed manual, a stronger transfer case, and better brakes. After a lot of research and number crunching I found it was cheaper to swap the Wagoneer onto a chassis that already had everything I wanted. No shit. A lot more work... but cheaper. In the end, it came out better than I expected. https://www.fsjnetwork.com/forum/viewtopic.php?f=12&t=21401
After that was done, I had a left over perfectly good Wagoneer chassis and drivetrain and my sister's Bronco II wasn't running... sooo... frame swap number two.
That looks like a lot of work. Did you just use the Jeep chassis because you had it? I haven't seen a Wagoneer in decades, Rambler/AMC steel is soluble in road salt and NH makes sure to use plenty.
I'll have to dig up the actual number of inches I had to shorten the frame but it was about 16" inches I think. I cut the sections from just in front of the rear wheels then used the sections I cut out as the plates I used to hold the two frame sections together. I drilled holes in the plate and bolted it together. Once I was sure the frame was straight I welded it up. I had to cut out sections in the fire wall to make room for the V8 banks and then welded up new covers to fill the holes.
I bought a non-running Ford Ranger for $150, an 1989 model year I think, and cut off the rear of the bed and welded it to the rear of the Bronco that had the upper portion and rear section of the rear cut off. I welded steel sheet to the bed rails and up around on the newly removed roof. The rear fender wells were cut and narrowed to give more usable bed width. A much better aluminum radiator was fitted which required trimming around the radiator supports along with lowering the top of the lower support. The radiator is for a Ford Explorer, I'll have to look up the model year. Here are a few pics that are on my computer, I'll have to load some more later from my phone and take a few more as well.
19Walt93, I convinced my sister to do the swap because of a couple of reasons. One, she had installed a 4" body lift so she could fit bigger tires and I hate body lifts, friends don't let friends install body lifts. Two, the tiny underpowered 2.9 V6 stopped running and I didn't want to waste my time making that dingy anchor run. Three, the Waggy already had a proper suspension lift, bigger rims and tires, and a big V8 with much stronger Dana 44 axles just begging to be used.
A few more pics.
This is where I cut the frame in two.
I had to notch the lower support to clear the wagoneer steering gear box.
Top removed and inside view of bed. The raw cuts were capped with steel sheet.
Radiator support
Firewall pushed back about 2" to clear V8
Interior pics
There is a seam about six inches in from the end of the bed. I cut the Bronco and the Ranger at this seam.
Featured Ranger Based Vehicle
