IS there not a way to snake the gasket up in there and in plae with out totally removing the pan? I did several of the BMW X series cars (All wheel Drive) they have an axel shaft that goes thru the oil pan. What I did was raise the engine a bit, drop the pan covered the pan with paper towels and plastic to clean the block mating surface. Once everything up top was cleaned off I would uncover the pan clean it off and then snake the gasket into place. Make sure the gasket is clean and put it all together.
I would never use silicone on a rubber style gasket except at the corners, where you have break lines for assembly.
