I have an update: I had to repair two traces, replace three capacitors, and four resistors. I don't have the tantanum, and I need to conformal coat the areas where I removed it, so I'll do that later.
The truck started right up and runs like a top.
I am by no means an expert at board repair, so probably better ways to get this done.
I found it best to clip out the bad components, scratch with the fiberglass pen to remove conformal coating, solder mask, and corrosion. The electrolite gets under the conformal coats and solder mask and eats the copper away.
Flux the area and add new solder to melt the old solder, pull the legs out.
I used the needles to clean out the holes; solder wick would work too.
I used my ultrasonic cleaner with a mild solution of white vinegar to clean up as much of the mess as I could.
A tip: with a UV light, you can see where the electrolyte has leaked.
For the traces that were damaged, I used magnet wire to make the repairs. Coated the clean copper and the magnet wire repairs with UV-cure coating.
Make sure you use an ohm meter to verify your repairs. The vias can also be eaten away, and that's a tougher repair; that's when you have to run bodge wires to complete the circuit.
The resistor values were guessed, I decoded the best I could, and compared them to photos online. I hope they're right
My ECU is from a 93 4.0L Ranger, if that helps anyone. If I were not in a hurry to get everything running, I would have made a video.
I used
- One 10uf 63v 105c capacitor (buy high-quality caps)
- Two 47uf 16v 105c capacitors (buy high-quality caps)
- Two 200-ohm 1/2w metal film resistors (just what I had on hand)
- One 510-ohn 1/2w metal film resistor (just what I had on hand)
- One 2k-ohm 1/4w metal film resistor (just what I had on hand)
Tools and supplies you might want
- Solder Iron, of course
- Solder
- Solder wick and or stainless steel non-stick tin hollow core needle (Great for cleaning the throw holes out)
- Lots of flux
- conformal coating
- magnet wire
- Fiberglass Scratch Brush (works great for removing the solder mask, conformal coating, corrosion.
- UV-cure solder mask.
View attachment 130592View attachment 130593View attachment 130595View attachment 130596View attachment 130597View attachment 130598View attachment 130599View attachment 130600View attachment 130601View attachment 130602
