Fellows. Got a Check Engine Light a couple weeks ago while highway driving on my way home (65mph or so). Stopped at a auto parts store to get it scanned and it was obvious the warmed up engine idle was rough when I pulled into the parking lot. (I figured something was misfiring). The auto parts store scanned it for me and the error code was P0306, #6 cylinder misfire.
Drove it home and noticed that during moderately hard acceleration and at highway speed driving I do NOT notice a misfire. Might be there but by the seat of my pants I don't notice/feel it.
At home the idle was rough as it had been at the auto store parking lot.
Pulled the #6 plug (Motorcraft SP 500 with 45K on them). Clean.... with a .044ish gap on them just as I had installed them. Reinstall it, disconnected the battery and left it that way till the next morning.
Started the truck up the next day. Started fine as usual but had a bit of roughness. READING thru some other posts, I see others have 3.0l that have a bit of idle roughness.
Drove the truck another couple hundred miles. The idle gets roughish after the engine is THOROUGHLY warmed up but again on moderately hard acceleration and/or a highway speeds I don't notice a misfire.
Got another CEL. Swapped the #5 and #6 plug wires ( their the original wires... I bought the truck new in 2002). Cleared the code and the truck performed the same as above.
Couple hundred miles later... another CEL. Came to the Forum and posts here led me to install a new Motorcraft coil pack. I found that the OEM unit was cracked in several places. Put the #5 and #6 wires back on their own plugs.
Again, cleared the code. Cold idle was still a bit rough but after another hundred miles or so ANOTHER CEL came on. All the while I could tell the warmed up engine idle was/is rougher than a cold idle.
Again swapped the #5 and #6 wires. (definition of insanity ?) Cleared the code and ran the truck another couple hundred miles. Again, cold idle a bit roughish but warmed up idle noticeably rougher . CEL came on again on my return home via the highway. Had another auto parts store scan the truck and they came up with...P0306....and no other codes.
So... I'm concluding that the #5 and #6 wires are OK as the problem didn't follow to #5 cylinder. .... I just received a NEW set of Motorcraft wires as I figure with 245k on the truck (and wires) what the heck...its just $$$$. AND that the OEM cracked coil wasn't the cause either.
This morning I started the truck and the cold idle was/is slightly roughish (as it always seems to have been). Didn't drive it and came here to post this.
SO... any ideas? I read thru the posts and see that others have had "similar" problems...some finding that it was bad valves....errrrrrr. Hope not. Others found bad fuel injectors.
I opened a propane bottle around various vacuum lines and connections while the engine was running (cold) ..... didn't notice any difference in idle.
My mileage hasn't changed noticeably. I have always logged all my fill ups (since I started driving 50 some years ago).
It seems to me my biggest CLUE to whatever my problem is how the cold engine idle roughness is ALOT less than the warm engine idle. What's cousing this????? No idea.
Thoughts?
2002 Ranger Edge Auto/2WD/ 3.0l Cyclone/ 245k miles/ Maintenance done religiously and some items more so. Motorcraft parts used (almost) exclusively.
Thanks all.....
Again swapped the
Thoughts?
Thanks all.....
Again swapped the
