3.0 Timing Help
Any chance you set #1 to TDC exhaust? Regardless you should get some pops and bangs. You sure the injectors are firing? If you pull a plug after trying to start it, is it wet with gas? Have you tried spraying some flammable liquid into the throttle body to see if you get anything then?
Yes I've tried all that and still nothing. Checked for spark multiple ways, tested injector wiring with test noid, I did another cold compression test, all spark plugs out and got about 130ish on each cylinder. I might not be getting fuel pressure so checking that next.
I second that. I would try a little starter fluid. Then at least you could narrow it down.
