2002 Ranger Edge 3.0 4X4 MAP OR MAS?
Featured Build Threads
blue_strat
2002 Ranger Edge 3.0 4X4 MAP OR MAS? I'm told if I have a MAP, then I don't have a MAS and visa-versa. Is this true, or can it have both a MAP and a MAS? Thank you.
Sorry I can't answer your question. Do you mean "MAP or MAF"? as in Manifold Air Pressure or Mass Air Flow. MAS is new to me.
If you have a MAF, which I believe is what you should have, it will be attached to the air tube where it exits the air filter box. I also believe you are correct that ypu will only have one of those sensors and not both. It has to do with how the computer measures air mass and calculates corresponding fuel flow for the proper sir to fuel ratio.
And I removed your duplicate thread. You only need one thread per subject.
Rockauto only lists a MAF for that year. Unsurprising since most things went to MAF in the early 90s.
The 91 4.0 does have both sensors. But the "MAP" isn't actually connected to the intake and is called Barometric Pressure Sensor. By 92 someone figured out that was unnecessary.
Thanks for the duplicate removal. The first one didn't show up and I assumed it didn't go through and is the reason for the duplicate. My apologies for any misunderstanding.
As far as my MAS mention, I'm referring to the mass airflow sensor.
As far as the reason(s) for my post, usually once the truck is warmed up, it chugs at an idle, but smooths out under load. Then other times it doesn't chug at all at an idle, in traffic or otherwise. So I started researching what may be the cause. MAP, MAF, TPS, o2, etc. Currently in the trial by error stage. Already replaced TPS. Also no codes came up, so that's no help.
What rpm does it idle at? Is the Idle Air Control valve working and clean? Throttlebody clean? Absolutely no codes showing?
Hate to see people wasting money on "trial and error", or what we call the "parts canon".
How many miles are on it? And your OEM Mass Airflow sensor is 100x better than any aftermarket one so I would clean it first before replacing. Carefully pop it out after removing the 2 safety torx screws and hose it down with Mass Airflow cleaner.
Your 03 has a MAFS - mass airflow sensor. It may need to be cleaned. Get only a cleaner for airflow sensors and spray that on the wire of the sensor. You may or may not need to remove the MAFS from the intake tube to do this.
Featured Ranger Based Vehicle
