Thanks for the duplicate removal. The first one didn't show up and I assumed it didn't go through and is the reason for the duplicate. My apologies for any misunderstanding.
As far as my MAS mention, I'm referring to the mass airflow sensor.
As far as the reason(s) for my post, usually once the truck is warmed up, it chugs at an idle, but smooths out under load. Then other times it doesn't chug at all at an idle, in traffic or otherwise. So I started researching what may be the cause. MAP, MAF, TPS, o2, etc. Currently in the trial by error stage. Already replaced TPS. Also no codes came up, so that's no help.
