- Jul 27, 2024
- Georgia
- 2.3L
- Automatic
- Tire Size
- 265/75/15
No connection loss when I wiggle the connector or the wiresWiggle the tps connector while you sweep the throttle with forscan hooked up again. You should see if there's a bad connection. Also make sure the throttle shaft isn't over rotating the sensor. Unbolt the tps and hold the throttle wide open. Slip the sensor over the shaft and rotate it by hand to see if the bolt holes line back up.
I think I did the test you described correctly? If so everything lines up and looks fine there
