Dash vent fan clicking noise
Featured Build Threads
Vinny68
Forum Member
Bloomington, IL
Just recently got my dash vents working again after fixing a vacuum hose leak. But now the vent fan makes an annoying clicking sounds at all speeds. Has anyone ever had that issue and successfully fixed/replaced the fan? I assume some disassembly of the dash is required?
it is probably a leaf caught in the blower. it will eventually go away as the leaf disintegrates, although a removal of the blower motor assembly might not be a bad idea any ways to clean it...
AJ
I second that statement. Either way getting the blower out would let you know for sure. Blowers are dirt cheap in the local yard too, if you needed one. My truck is on it's third that I'm aware of.
I found a mouse nest in mine. Better check it out
Featured Ranger Based Vehicle
