Where can I get a standard rear brake drum puller?
jimmyess333
Killeen TX
2.3
All I can find is the kind that hooks to the wheel studs like for the rear drum of a front wheel drive car or the old classic front drums.
What I need is the typical 2 or 3 jaw puller that hooks to the lip of a rear drum, the kind of drum that slides over the studs.
I've looked at Sears, Snap On, Ebay, Harbor Freight, Tractor Supply Co, JC Whitney, Google search...and I'm simply amazed that this tool is not easy to find.
I should have been tripping over it with only one search.
Does anyone know a place that still sells a typical drum puller?
rockwerks
1994 mazda b400
1996 Jeep chero
You dont need a puller. Ive never seen one, needed one, or used one in 30 years of automotive work. the drum should just pull off if it wont you need to use the adjuster to loosen the shoes or tap the edge of the drum rotate and tap rotate and tap until it works loose
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
i use a big hammer and smack the flange. pops right off assuming the shoes aren't stuck
jimmyess333
Killeen TX
2.3
You're right, they should just pull off...but sometimes they don't.
It's not hanging up on the shoes, the adjuster is loosened and the drum/axle spins free. It's hanging up on the center where the hub on the axle flange goes through the drum.
I sprayed it with WD-40 and tapped, pulled, tapped and pulled, tapped some more.
I've been doing this for 25 years and never used a drum puller before either(although I have seen them). I'm telling you I need a puller for this one.
I know you don't actually use the puller to do all the work but I'd like to put some tension on it while I work on getting the drum off.
94twodoor
South Detroit burbs
4 cyl
Try your local auto parts stores. The ones here in Michigan have a tool rental program. Check at Orielys if ya got one.
rockwerks
1994 mazda b400
1996 Jeep chero
mini274
Elizabethton, TN
302
or a big screw driver while you tap works for me
jimmyess333
Killeen TX
2.3
Thanks but that one pulls on the wheel studs, it's only good for drums that have the studs in it.
The wheel studs on most rear wheel drive applications are connected to the axle flange, not the drum.
You can pull on the studs all day and you're not pulling on ther drum.
jimmyess333
Killeen TX
2.3
I tried at other stores and they kept trying to give me the wrong kind or didn't know what i was talking about at all.
I haven't tried Orielys though, I'll give them a try.
rockwerks
1994 mazda b400
1996 Jeep chero
You will not find one other than the one I posted. your only chance would be a massive gear puller and that will cost you as much as a rear axle
Dusty_Ranger
4
Salmo BC Canada
if the center bore of the drum is stuck on the rear axle hub, hunt down a lil propane torch and heat up the drum itself around the hub, the heat will expand the metal around the hub and wheel studs and u can use a hamer and pop the drum off, oh and btw mr 30 years experience should of known about this trick its been done many times befor
7.5L_STX
73
Up Dere In Da U.P. EH!
unnecessary
on tough ones i was always taught to us a prybar and gently (or roughly if you dont mind messed up threads on your studs) go around the edge of the drum and keep prying it off.
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
are you sure its not getting caught on the shoes? does it have any movement at all?
Doom's Day Custom
5
nj
4.0l
This will work for you and it's cheap
8" Three-Jaw Puller
A must for removing gears, sprockets, bearings, pulleys, and much more.
Rugged heat-treated carbon steel
Highly polished chrome finish
Hex end size: 18mm
Screw diameter: 5/8"; Reach: 7-3/8"
ITEM 40970-3VGA
$13.99
john112deere
central Vermont
2.3 / 4.0
First time I pulled my '97 rear brakes apart (truck had 230k or so on it; I know they hadn't been apart in at least 30k before that) I had the same problem.
Took probably 20 minutes of heating with a propane torch, Liquid Wrench-ing, tapping around the circumference of the drum with a hammer, and prying gently (so as not to damage the backing plate), all as close to simultaneously as I could manage with only two hands.
I don't think a standard three-jaw puller would work- can't figure where it would be able to grab on the drum. With a welder, grinder, and some scrap steel you could certainly modify it to work...and I've certainly custom-fabbed pullers like that for other purposes, but I'd say heat, good penetrant (not WD-40), tapping, and patience are probably easier in this case.
Or you could take the axle out and knock it off from the other side. That's actually how I did it on the second side of the '97 that first time...but only because the reason I was working back there was a leaking seal, so it was all coming apart anyway. If it's about time to change the diff oil anyway it's worth considering, I guess.
