Hello everyone, it is good to finally make my first post and series of inquiries regarding some ranger goals I have in mind, moving forward with a future project truck. I'll post an introduction later separately to keep this as short as possible. I am currently at a phase in my life where my next 3 years in my career will be a bit of a break in comparison to the last 8 that I have experienced, which means I will have much more time to pursue this project. And while everything I am asking about here has been done before, I have yet to hear of any build that sort of ties it all together into one vehicle, which is exactly my objective. The purpose of this truck, though I would argue is irrelevant to need to know, is to have something that is reliable enough to daily should I ever need to (if one of my bikes goes down that I daily, this never happens knock on wood), but mainly to have a project truck that checks all the boxes of what I want it to have and what I want it to do (be a reliable novelty ranger, be able to tow at least 5000 pounds, meet the cosmetic looks I have in mind, have the utility of the flatbed I have in mind, and have the off roading prowess in mind although this is not intended to be a trophy truck). Most of the time, I will likely use this truck to have fun recreationally on and off road, and transport tools and heavy equipment both on the flatbed and/or on my 10-foot flat trailer.
I am seeking the bottomless knowledge and experience from all you been-there-done-that guys who can help me in my decision, and maybe tell me if and how these mods may conflict, and what exact parts and specs are needed in order to pull this off. One last thing before getting into my desired mods for the Ranger, try to refrain from commenting about difference in money/investment factors. Yes, a brand new TRD Pro Tacoma will be 50-55k most likely (this is the option 2 I will pursue if this ranger build does not work out for some reason), possibly more, while a 3rd gen Ranger can be found anywhere from 2-10k. But please, I just want to discuss these 3rd gen mods and iron out my plan, should I choose this route for a custom RBV. If I can source the doner ranger (So far I believe this to be a 2004+ extended cab manual 4.0 4x4) for no more than 7k, and spend no more than 20-25k in parts and labor (mainly parts, as I am willing to do most of the labor myself), then that would be awesome. I have not yet done a deep cost analysis because I still need more answers on what exactly must be done and ordered, hence this post.
All said and done, I am looking to have the following capabilities/features on the truck: (1) fiberwerx gen 2 raptor front end, custom flatbed in the rear, (2) 33s or 35s, I have a bead lock wheel in mind from BRA that I like, I don't know what size wheel yet or whether or not to offset because this will depend on what I can tow, (3) I'd like about a 4" lift (+ or - 2" if other mods require it as such), I don't know differences in a torsion bar setup or a coil setup, still need to figure this out. Whatever decision comes of this, I am a huge King suspension fan so I will use their stuff wherever possible. (4) 302 HO motor swap with a manual trans (R2? maybe a ZF?) and manual t-case and doubler (1354 + doubler kit perhaps behemoth OR 1354+_____?) (want dual sticks (Pretty sure that doing this with a 4" lift is quite do-able with little to no cutting for the sticks clearance, let me know what you think)
I definitely need an extended cab RBV, and ideally if I can get one with the bench seat and flip down center console in the front that would be awesome! I also imagine that the solid 8.8 rear would be the way to go on this, which leads me to believe that I should seek a 4.0 motor variant RBV as well since they all have em stock to begin with. Don't know what gearing for the axles and T-cases yet though.
Keep in mind the following questions I have when reading this list of desired mods:
1) What donor vehicle? I have had a 2004+ Extended Cab with manual trans model in mind. I have to have jump seats.
2) Are there any 2004+ model year Manual, extended cab rangers that have bench seats with the drop-down middle seat/center console? That would be ideal. If not, does anyone have a bench seat that you can install in the extended cab?
3) Any special considerations for the best frame to use? I imagine some sort of aftermarket cross members will have to be bought and bolted on or welded. OR perhaps a custom one entirely must be fab'd. I do have my own welding set up and a lathe, and a mill in my garage that I call a shop lol. Other than that, I do not know if certain model year or manual/auto style frames have different benefits when talking about the swap described above.
4) EFI or Carb setup? While I am not necessarily planning on turbo-ing it in the future, I would like to have that as an option, and I understand EFI would probably be the best way to keep this door open.
Feel free to point out any other issues or questions worth mentioning that can help me make this possible
5) After swapping to a 302 motor, if I do a 347 in the future and/or turbo it (would most definitely be a low boost application if I were to ever do this), at what point is too much power for the R2 transmission and T-cases? Are there any stronger gearsets/shafts out there off the shelf to swap for the R2 transmission in order to support more power? (Billet, etc) I know, this is getting a little too far down the road, but it's something to consider. The more thought I frontload into this, the less pain I will have down the road when I finetune what I want and like on it, or further modify in the future.
Some other questions I have:
- Is there any reason or way to reinforce the frame? Or to slightly increase the towing capacity of the vehicle when considering some of the other mods I list below? Cooling mods?
Thanks for reading! What do you guys think? Feel free to share your thoughts and comments/critiques on how to improve where I'm going with this.
