Track Bar Questions
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Finishing up the solid axle in the 91, its a narrowed HP 44 with early bronco shafts. i have a stock 79 F150 trackbar i was going to cut down and sleeve it with leftover DOM from my steering kit, but it would be nice to make it adjustable.
I saw where a guy had cut out a section on his track bar and faced, drilled and tapped the two pieces in a lathe and made it adjustable. I have access to lathes and bridgeports at work, what do you guys think of this? I know I shouldn't be trying to cheap out at this point but I just want to get the damn thing done.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
It would be cheaper/time efficient if you just bought the DOM and inserts and did it right the FIRST time.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
get a weld in bung and a rod end for the DOM that you sleeve the TB with and it'll be adjustable
