Taking longer to start?
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
No way around it. It needs to be changed. I went to harbor freight in gautier today and bought some goodies for our shop gator. :icon_hornsup:
gungfudan
19
Mississippi
Mazda
N/A
N/A
What is the typical idle rpm for the 3.0
Craig0320
225
Mississppi
750 or so warmed up in park
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
mine idles around 900 rpm. its just a tad shy of the "1" digit on the gauge so I'd say around 900. mine is a 99 3.0 if that makes a difference for you. I would replace the fuel pump and go from there. It wont hurt anything to replace it. If it dropped to 10 psi then I would suspect the fuel pump for sure. Mine was doing that crap last summer and I replaced everything but the fuel pump only to end up replacing the fuel pump and then problem solved.
gungfudan
19
Mississippi
Mazda
N/A
N/A
Well I got the Fuel Pump but I am 3.5 hours away from the house with no tools so I am praying I make it home Friday.
gungfudan
19
Mississippi
Mazda
N/A
N/A
Well replaced the fuel pump and the pressure is holding a little above 30 psi.
Craig0320
225
Mississppi
Engine idling should be around 30-40 psi. So you should be good. It should seem like a different truck now.
gungfudan
19
Mississippi
Mazda
N/A
N/A
So is the problem solved?
Yes it is solved
Sorry for the late reply I am offshore on a platform right now not always great internet
