- Feb 22, 2011
- 19
- Mississippi
- Mazda
- Engine Type
- 3.0 V6
- Engine Size
- 3.0
- 2WD / 4WD
- 2WD
- Total Lift
- N/A
- Total Drop
- N/A
stick with recommended factory replacement injectors
a lot of those accel injectors have significantly different offsets (solenoid dead time from when its get powered up before the injector actually starts spraying fuel) and it can cause some fueling issues sometimes
I would suspect your fuel pump first though. The early signs of a fuel pump going out is extended cold starts. if you hadn't changed the filter recently i'd prob check there too just for good measure.
I did change the fuel filter. I will check into to the fuel pressure. I am out of town at the moment so I will touch base with you later CraigIf you don't have a fuel pressure gauge I have one you can borrow. I would definitely check the pressure first. Mine does this on and off but my pressure bleeds of rapidly. I bought a brand new fuel pump 4 months ago but didn't put it in because it was hunting season
