- Aug 31, 2021
- Reaction score
- 974
- Location
- Roanoke VA
- 1997 and 1999
- Make / Model
- XLT 4x4 & B3000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L in XLT, 3.0L in B3000
- Automatic
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
@Josh B yes it's the same tire, and I like the tire, but rotating the picture, which is all you can do with a tire, doesn't change it. Not sure what you're using, but "flip" in photo edit creates a mirror image (what you did), something you can't do with an actual tire short of making 2 sets of molds and making 2 different tires. For confirmation, you can take a slip of paper and make it a circle, or cut a length of paper towel core, and draw the diagonal lines across it. You can turn it any which way you want, but it won't change. I know it seems counterintuitive, but try it and you'll see. Seriously.
@pjtoledo Thanks for giving me the formula!
@ericbphoto It is about the same here usually just a few snows I am somewhat north of you. What was the main factor in going to the bigger diameter, height? I assume you had to lift the truck.
@Blmpkn Yes that's the issue, turns out there are symmetric tires, either directional or non-directional, just not in a/t, you'd have to go to mudders. Probably not a good choice for me. I can't say for sure since I haven't been these places, lacking 4x4 previously, but I think mostly roads are going up in elevation which would imply drier not wetter. It's true you can run into soft/muddy spots, but I think you see this mostly when you have to pull off the road to let someone by and it's mucky there. But mostly I think what I'll run into is gulleys in the road, rocks, etc.
If I have only one set of tires, and they fit stock wheels, which is of course the easiest and cheapest solution, even though snow is infrequent, they should be good in snow. The short story is I was stuck last winter in my 2wd just coming out of the driveway. I know I could do better with weight in the back, or chains, but anyway, there are several guys right near me who have mid-size 4x4 with pretty aggressive tires (a/t) and they have no problems. So it became a thing with me that "I won't be in that situation again". Probably I wouldn't have got the '97 just for that. I also like to go up the county / forest service roads which usually start off nice, there are a few houses, then they get progressively worse until you see a sign "No maintenance past this point". These are old logging roads and forest service roads (latter usually marked with, I think, yellow 3-digit signs). As long as they aren't posted or gated, you can go up any of these roads, it's public domain and the Forest Service told me there is no restriction on driving them unless otherwise posted/gated. There is only one even remotely nearby "Potts Jeep Trail" that might be regulated. But that aside, I could probably spend years going on a different road every time and still not hit all the back roads here say within 50 miles.
Got off topic, anyway, so far, I don't think I'm going to find symmetric a/t tires and I agree with the several comments that it really doesn't matter and as to them being mirrors side to side on the truck, no one cares (except me) and it doesn't affect performance. I'm not going to give up but sooner or later I have to do something because it looks to me like one of the DIscoverers might be showing cord (something white, not letters) at the sidewall and if that's true then it's not what I'd call a good tire. And they only have about 4 to 5mm tread left.
I do recall when I lived up north we always had 2 sets of tires and, yeah, snows are vastly different than mudders.
