Stationary back window
Chadk96xlt
Pasadena M.D.
Ford ranger xlt
I recently broke out the sliding window of my 96 Ford Ranger XLT Super Cab I'm looking to replace it with a stationary back window but I'm having a hard time finding a window that'll fit what other windows will fit my back window to make it stationary
3,614
86 through 2011 super cab rear windows are interchangeable, sliding and fixed.
Chadk96xlt
Pasadena M.D.
Ford ranger xlt
So even if it says the part won't fit it will?
8,374
Yes, it will
Welcome to TRS :)
Also 1998 to 2011 Regular cab, they changed to bolt in windows
In about 2005 Ford added 2 more studs to the top of these windows so you would need to drill 2 new holes in top frame
All super cabs used bolt in rear glass, slider or solid, 3 studs on top, 3 on bottom, 1 on each side
In 2005 they added 2 more on the top
In 1998 Regular cabs were switched to these same bolt in windows, they previously used different size glass and no bolts, just a gasket seal held them in place
Now, I have read of 2 super cabs that had the gasket type rear windows, so this is a "general" rule
I would pull the interior panels to see if you have bolt in or gasket type BEFORE buying a replacement, then get replacement for what YOU have on the 1996
This article is about removing the gasket type rear window on regular cabs: https://www.therangerstation.com/Magazine/spring2009/remove_rear_window.shtml
Here is a picture of the bolt in window frame, you can see the holes for the studs on the rear window frame: https://www.ranger-forums.com/attachments/exterior-semi-tech-39/176896d1501424019-back-sliding-window-question-103-0333_img.jpg
There are videos on replacing these
