Starter gear problem
enginepaul
12
Northern California
2.8
I've been having starter problems and need to know if anyone here has use the 10 (ten) tooth gear on their 2.8 with 5 speed transmission.
I'm on my third starter in about six months; they work at first, then they get noisy and eventually just spin.
I have replaced the flywheel, but ordered a new one and before attacking this mess, I have heard that the 10 tooth is the proper gear, but the ones I have on hand are 9 tooth - I don't have the one that has been in there for about ten years with no problems until the end.
TimR
Ambridge, PA
the problem is, all the auto parts say there is no difference in the automatic starter... BS. Get a Reman, from Ford, it is the only option, unless you get the nose cone off of an original stick starter. the nose rotation is off by about a 1/4".
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
Im running a starter off an auto tranny on my manual tranny, TK4, if that helps any. But I am running an 85 flywheel, bellhouse and internal slave too on my 84 engine all in front of an 83 tranny.
If I do get a new one, I go to autozone and get one with a LLT warrenty on it and Im good to go.
TimR
Ambridge, PA
yup, as long as you don't mind changing them every week or so... lol
enginepaul
12
Northern California
2.8
Nice tips - except that I do have a Ford re-manufactured starter with the same problem as before. Autozone gives a great warantee on paper - bought one from them right around the corner from where I broke down the first time and they WOULD NOT give me back my money; guy said I need a recipient for the one I bought elsewhere to replace their junk part. (had the same problem with a brake booster, but took another chance because it was in walking distance)
One lesson that I learned is not to get the core charge until after the new part works for a while.
I'll look into the auto trans starter situation.
TimR
Ambridge, PA
And you told Ford it was a Stick? They should know better...
dangerranger83
54
Lafayette, IN
My autozone keeps all the warrenty stuff in there computer system. Had to replace a coil and dura-box a few months back and all they did was look it up and say ok. All I had to do was give back the one that I bought from them.
user111
Southern Indiana
I have a automatic and had starter problems, finally I learn that I needed a spacer. I forget now but there is a way to check alingment of Starter gear to flywheel gear, Check out how the the starter gear engages flywheel. Auto zone does seem to have good rebuilt starters now as I got my last one there ...and also the spacer. I regret I lost the information on how to check alignment of Starter gear to Flywheel.
enginepaul
12
Northern California
2.8
An update. I put in a ten tooth gear and everything was fine except that I also replaced the solenoid with the 'best' that O'Rielly has. The made in China solenoid stuck once; a junk-yard genuine Ford part is better.
I just put in a new fly-wheel and original 9-tooth starter and will see how this works. Unfortunately, this is a China flywheel too. We shall see, but for now it is fine.
FYI: The starter can only go on one way and the clearance is determined by the rear engine plate and when I bolted it to the transmission bell-housing, it didn't make more than a couple thousandths of difference. Some Fords could use a flywheel shim, but not these Rangers.
Auto and stick starters are the same from the parts stores. If there is a difference from the factory, it would be slight if any. I held an auto and a stick starter-drive together and didn't see and difference - but I didn't use a micrometer to see if there were any measurable differences.
