spark plug change 1998 4 cl (is it hard)
MetalMulisha619
What is the easiest was of changing the spark plugs due to location? any help would be greatly appreciated.
Earl43P
38
Farmington, Pa
Ford F250 4WD
Use a variety of extensions (I like the wobble extensions a lot) and a swivel adapter.
I wouldn't hesitate to mix 3/8" drive and 1/4" drive adapters/extensions either.
Personally, on the v6's I take the front tires off and go in through the wheelwell, the gap guard comes right off.
I like working sitting down better than leaning over a fender.
4 banger, I'd do from the top though. I have no idea which you are working on.
greenpus
2.5
Take the upper intake off. slick as snot and a whole lot easier than messing with extensions :beer:
Bryan22
4
So-Cal babay
94 extd
94 2.3
Everyone has their own way, as far as im concerned a 6 in extension a u joint and a 3 in extension is not too much to mess with. i can change all 8 of mine without disassembling anything in about 40 mins, and that's including having a beer break. haha. it's handty to have a peice of hose that fits snug around the top of a spark plug to get the new plugs started too.
BlueChariot
28
Thomasville, Georgia
'94
Mazda
X2. Extensions arent that bad.
Luckily I have 2 sockets specifically for plugs in my ratchet/socket set :D
greenpus
2.5
so can i and within the same time frame I can also replace the PCV and the coolant hoses that run from the intake manifold to the engine and heater core hose :headbang: which you can't :D
modelageek
14
Boston, MA
I have done the 2.5 3 times now.......the last time i swapped the plugs and wires and i did it in an hour and I did not remove the intake.........make sure you use autolite or motorcraft plugs and that if you get new wires get the ones that have the hooks on them.........I used autolite wires for about $26
modelageek
14
Boston, MA
that is the only good reason I have heard for taking the intake off when you do the plugs........so you can change that coolant line to the TB.......otherwise it is not necessary IMHO
Bryan22
4
So-Cal babay
94 extd
94 2.3
I can reach behind the intake manifold and change the PCV in 5 seconds. And I wasn't trying to say your way was wrong. whatever suits the person working on it best is the right way for that person.
