MetalMulisha619
- Nov 17, 2010
- 0
- ford
What is the easiest was of changing the spark plugs due to location? any help would be greatly appreciated.
Take the upper intake off. slick as snot and a whole lot easier than messing with extensionsWhat is the easiest was of changing the spark plugs due to location? any help would be greatly appreciated.
Everyone has their own way, as far as im concerned a 6 in extension a u joint and a 3 in extension is not too much to mess with. i can change all 8 of mine without disassembling anything in about 40 mins, and that's including having a beer break. haha. it's handty to have a peice of hose that fits snug around the top of a spark plug to get the new plugs started too.Take the upper intake off. slick as snot and a whole lot easier than messing with extensions![]()
X2. Extensions arent that bad.Everyone has their own way, as far as im concerned a 6 in extension a u joint and a 3 in extension is not too much to mess with. i can change all 8 of mine without disassembling anything in about 40 mins, and that's including having a beer break. haha. it's handty to have a peice of hose that fits snug around the top of a spark plug to get the new plugs started too.
so can i and within the same time frame I can also replace the PCV and the coolant hoses that run from the intake manifold to the engine and heater core hoseEveryone has their own way, as far as im concerned a 6 in extension a u joint and a 3 in extension is not too much to mess with. i can change all 8 of mine without disassembling anything in about 40 mins,
that is the only good reason I have heard for taking the intake off when you do the plugs........so you can change that coolant line to the TB.......otherwise it is not necessary IMHOso can i and within the same time frame I can also replace the PCV and the coolant hoses that run from the intake manifold to the engine and heater core hosewhich you can't
