Some INFO
ranger28
i have a welded trush muffler on my 4.0 ranger the tone is asome but its not to loud had it on about an hour I was wondering if anyone has had one and if it got louder? after like the "break in period"......... and if anyones got any ideas to make it louder with changing anything majior???
does tips help? and what do they do?
RangerFabWorks
The O.G blackwidow67
Forum Moderator
540
Lexington, North Carolina
302
Does it have a resonator on it? If so remove that and it will sound awesome.
I just put the same muffler on my 98 explorer and loved the sound but the drone was too much so I put the resonator back on.
If you go to a 2.5 inch tailpipe it will sound even better. I plan to do that with mine
Z3CHYD
16
Lancaster, PA
3 front 5 rear
225/60R15
All depends on how your exhaust is setup. Do you have it dumped, hooked up to the stock piping out the back, dumped out the side? Whatever you have, upgrading after the muffler to 2.5 will make it sound deeper. And like you said, after the break in period, it will get "louder-ish" and sound even deeper.
ranger28
thanks for the advice guys..... and i thought i would post the set up sock pipeing to muffler the 2.25 out.
Ranger Kip
10
Wellsboro, PA
Ford Fleet
3.slow
Confused and Intolerant
put your original muffler on, drill a few holes in it, and you get a loud sound =)
dirttrackracer
Law Enforcement
9
Bloomsburg, PA
what about if i remove one of my 2 cats? im gona take this muffler off of my 78' and put it on the ranger
Akimbo Rangers
Northern Ohio
2.3 duraturd
Some aftermarket muffler have "batting" in them. its like a fiberglass mat wrapped around all the chambers and tubes in the muffler. i know for a fact thrush weldeds do no have any batting in them. the cheaper thrushes and glasspack do though. so eventually the batting will break loose and blow out of the muffler. thus why glasspacks sound like straight pipe after about 6 months.. to answer your question..... No, your truck will not get any louder but you can make it very irritating for people next to you if you do a side dump:icon_thumby::headbang:
