Ranger frame is actually 2 pieces
Derrick1970
Iowa
Triton V10
Hey Guys just found out something very interesting about my 2000 Ranger Extended Cab XLT. I was reading some stuff online as I have and idea I want to try with her. That being to find a 7 foot box and put it behind my extended cab. Yes that will mean I will have to Stretch my frame. Anyway as I was reading stuff I came across something about the frames rails on the Rangers not being all one piece. Sure enough when I went out and looked at mine there is a splice at the main eye spring hanger on the rear axle. Now the question I have here is are the frames on the Regular cab Ranger XL 4x4's the same way?
don4331
1,346
Calgary, AB
5.3
Derrick1970:
The answer is yes: 98+ regular cab frames separate the same way. Best part is you don't need a 4x4 frame, all long box frames are the same from the front spring mounts back.
http://www.therangerstation.com/forums/showthread.php?t=118209&highlight=supercab+longbox
Ingredients:
1 Supercab Ranger
1 Long box Ranger
6" extension to: Frame (section removed from Long box truck frame), drive shaft, brake line, charcoal canister tubing.
12" extension to rear wiring.
Ideally, you put the ex-super cab short box rear frame onto the shortened front frame, reinstall the old super cab box, install a regular cab, short box drive shaft and you can sell the regular cab, short box truck to recover some of your costs. (Replacing rear frame is a legit process for accident damage; there is a Ford bulletin on how to do it - replacing the rivets with the appropriate bolts).
Pictures of my example to follow.
97RangerXLT
3,938
Fishers, IN
2"
31"
I think AllanD did this...you might get a hold of him and pick his brain.
AJ
Sent from my Samsung Galaxy Note 4 while sitting in my underwear
I know Allan had talked about doing this, but I don't know if he even got around to it.
trail B2
8
North Eastern Ca.
My first thought Allen D
don4331
1,346
Calgary, AB
5.3
Pictures as promised
The candidate:
Rear frame removed. Note how close to the back of the frame the spare tire carrier is.
Box Donor:
Rear frame from the long box truck.
Note, the spare tire carrier is somewhat inset.
The long box is 6" longer from rear axle centreline to rear of frame.
Frame extension from donor vehicle
Adds 6" to the Super cab frame.
Doubler (tripler) 'cause I don't trust my welding...
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Derrick1970
Iowa
Triton V10
all this info is AWESOME guys thank you very much for that. I was actually wanting to find a regular cab long box and that was wrecked in the front and another extended cab short box like mine that was wrecked in the back and marry the two good halves of the wrecked trucks together. Yes I am planning on weldin the frames together too, cause i work my little ranger i have right now kinda hard.
