- Dec 21, 2008
- Reaction score
- 7
- Location
- Auburn, Wa
- Make / Model
- Ford
- Engine Size
- 3.0
- Manual
Thanks Man!Those look awesome dude, they put mine to shame
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I used a 3.5" hole saw on a drill. Probably not the best way to do it, I burned up my 110v drill, and blew the gearbox on my 18v dewalt, but the holes came out nice and round. Youll probably have an easier time on the 1/8th wall stuff...Just take your time and use lots of cutting fluid.nice work man, looks killer. you could probably run over some trees with bad boy.
mine is gonna look similar, but i'm gonna do it with some 2x4x.125 wall stock.
what'd you use to cut out for the lights? whole saw with a drill?
you tried to use a battery powered dewalt on the holes?? i guess an 18V could do the trick.I used a 3.5" hole saw on a drill. Probably not the best way to do it, I burned up my 110v drill, and blew the gearbox on my 18v dewalt, but the holes came out nice and round. Youll probably have an easier time on the 1/8th wall stuff...Just take your time and use lots of cutting fluid.
take the leftover of that 6x2 stock and make your own spring perches. you can cap the ends for strength and give yourself an extra 1.5"-2" of lift. to set the pinion angle a little better, you can bolt it all up, connect the d-shaft, tack the perches and then pull it out to fully weld itStock explorer 3 packs w/ the overload removed.... and my big ass shackles. I need about an inch more lift in the back, so im probably gonna mod a couple of 2" blocks and mill the angle I need to replace the degree shims (which suck anyway). I was thinking throwing a lighter AAL in there, as im not to hot on blocks, but I love the way this thing flexes and rides out back, So It will probably just get a couple of short blocks...
I think they are 5/8"s... Too lazy to go out and measure... lollooks sick. what size are your d rings?
