kmk1605juggalo
- Sep 7, 2010
- 0
- Ford
I have an 88 Ford ranger 2.9 L super cab 4x4. The truck has been lifted excessively and is in desperate need of the one piece drive shaft swap. Locally I have not been able to source one. I found one in a salvage yard in Phoenix (about 150 miles away) out of a 2003 ranger, 4x4, extended cab, shot flare side bed that has been rolled a couple of times and I want to make sure this is the right shaft before I drive up to get it. From what Ive read in the tech-section this should be the shaft that I need, correct? As long as the shaft is 47" from weld to weld it should be the part I need right? If I am comprehending everything Ill also need the flange that this bolts to the Transfer Case end to avoid using a specialty u-joint conversion correct? Any input is greatly appreciated... or if you have a one piece shaft you would like to rid yourself of please let me know....
