NEW 4WDs VS OLD 4WDs - Ronny Dahl
8,370
Yes, it was called welding the axles together, been around a long long time, fell out of favour when roads started to be paved, lol
Limited Slip was the solution to paved roads :)
rusty ol ranger
2.9 Mafia-Don
7,510
Michigan
177 CID
When were welders invented? i didnt think that came about till the 30s did it? Or am i stupid?
8,370
3000 B.C. was the oldest example of "welding", i.e. hammering metal together after heating
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Also known as forge welding.
1990RangerinSK
1,312
Saskatchewan, Canada
I think about this frequently..
So much of this country was discovered/settled/built by the model-t..
Yet every soccer mom who lives in a location where it might snow 1/2" a year absolutely NEEDS a giant 4x4 lol.
Actually, that's not true. Most of the USA was discovered and built by covered wagon. Usually pulled by a team of oxen.
rusty ol ranger
2.9 Mafia-Don
7,510
Michigan
177 CID
Discovered yes...built? No. It was largely built by internal combustion
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Listen up Canada... I've had enough of your facts for the day lol.
97RangerXLT
3,941
Fishers, IN
2"
31"
You have died of dysentery.
Really the steam locomotive is what allowed most of the early expansion and building. They were the first means to get people and supplies across the country quickly, then the telegraph made it able to communicate across the nation quickly.. The covered wagons dis the claiming and settling. The model T Era brought the peak of the industrial revolution.
AJ
sgtsandman
12,651
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
AJ
Also known as the external combustion engine.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
In sand is where the older ones do better, traction control on the new ones kills your momentum and gets you stuck, also the low profile tires on most new vehicles do terrible in the sand when aired down, plus they are heavier, which makes it even worse.
you are comparing standard traction control. and for sure.. that sux...
i am referring to something different.
trail biased traction control is a different animal.
when you are stuck in a conventional situation....it can drive you out.
and sure...it is not 100 percent.....but also its good enough....that is not a debate topic.
