Maxsevich11
Good day)
Could you please help.
There is a problem with the operation of the engine.
1 -The engine does not idle and stalls (rpm 300-400)
2 - When I press the throttle rpm does not increase
3 -The car jerks and spits
4 - check engine lights up, but there is nothing to read the code
5- this problem sometimes disappears by itself, today all bad, tomorrow all good (as if nothing had happened)
6- when I disconnect the MAF connector, everything works well, and the power is full. But if you plug it back in, everything goes bad.
Fuel pump is new, MAF is new (1 year old). Removed the ECM, looked at it and put it back. nothing has changed )
All engine sensors new ( ignition control module, distributor cap, spark harness, alternator, air temp sensor, coolant sensor and sender, throttle pos. sensor and idle , fuel pump relay and ECC relay all new)
Please help with advice, maybe someone has faced this problem?
Sorry for my bad Eng, i am Ukrainian)
Also video included
Also video included
