My 94 Ranger Recovery
4.0B2
151
Walls, MS
4.0 v6
Yes fords crapppy idea of a location for an air intake in a 4wd and my fiancee for saying "IS THAT ALL SHE GOTS?" before we hit a mud hole
you should make your fiancée buy you a snorkel.. :D
SAY789
6
Springfield Or
5.8L
Should but she'll tell me the wrong place to put it haha
4.0B2
151
Walls, MS
4.0 v6
gearhead51
Fitzwilliam, NH
looks sick!!! good job on the radius arms they look sweet
SAY789
6
Springfield Or
5.8L
Been some time since i updated so heres the low down.
Ran some 35's on her, loved it. Now if i can find someone to trade my like new 33s for 35s ill be set. LOVE the new suspension it rides soooo goood. Just need to push my radius arms forward another inch i think. Finally got some rear shackles to help make it look like a truck, not a baja 1000 truck.
Heres the new shackles for the rear gained 2.5" of lift
Here was a night run in the snow testing the suspension out
Posin with the new shackles on. She is sitting with 11" of lift now, 3" is a BL that is for anticpation for a 303 swap. Yes i know i need 35s
Now to figure out why my truck is cutting out. Going to get a new fuel filter but heres the skinny on how she has ran and what she is doin now.
There always has been a slight miniscute miss or stutter even with the other motor i had. When she is dead cold and i dont give her time to warm up if i SH** stomp it she will cut out and then drive fine. What i mean by cut out is that it acts like i turned the key off then right back on.
Now the other day i was towing a utility trailer and it cruised fine untill i went to pass. It cut out on me hard several times. On the way home it did it again and when i just held the throttle open it died once. Tried starting it and it just cranked bout 10 sec later it started. Now when im driving it cuts out every so often and its been really nice out and i had no trailer on.
Any ideas?? Ive tried a different coil pack, im going to get a fuel filter i pulled mine off and blew it out. hopefully its not a fuel pump
SAY789
6
Springfield Or
5.8L
To V8 or not to V8, that is the question i been debating hard since my engine problems. Still having no luck fixing the cutting out. Tried replacing sensors cleanin MAF etc but to no avail. Also put a new fuel filter in but no dice. Soo my buddy came up to me saying his friend has an 84? ish bronco with an HO302 auto 4x4 for $400 bucks. Im goin to take a look at it and if i deem it feesable im doin it. I believe i should be able to sell my motor trans and t case to cover the expenses.
Laid of for another 3 weeks so, so im hopin if all goes well i should have somethin figured out and done
SAY789
6
Springfield Or
5.8L
Turns out my cps wires got detached from the block retainer so the wires would move into the belt and it wore the plastic off them ths making them short out. Runs like a champ now.
Worked in my back yard a lil today and found a ditch that i decided to flex in and i wasnt very happy with how little the front flexed.
Also forgot about my coil spacers i made out of some scrap DOM and a set of spare coil seats that i welded that net 2"
Big pics for the haters lol
SAY789
6
Springfield Or
5.8L
Ill have more pics tommorow :icon_welder::icon_welder:
gearhead51
Fitzwilliam, NH
nice! are you gonna rig up the door handle so it works in that spot
SAY789
6
Springfield Or
5.8L
I was but i couldnt get the rod to function correctly. So i did the next best thing, i reused the cable operated interior handle and put it where the door vent was. It works great and from either inside or outside it is comfy to use.
I think im gonna do the other side now so i can do the body work to them together not one at a time. Gonna use some paint match and on the top im gonna bedline them for use as a step if needed
Then i think im just gonna use some 16 guage to make a door panel to make it look a lil better
In my opinion if anyone was to do this like this, cut and fold right above the door handle to retain it and hide the interior cable like shown on mine
SAY789
6
Springfield Or
5.8L
Meh not too much of an update just got some 3" 63's in the rear with no block and beltechs, got her level now. And started fabbing my new front bumper, still have alot to do to it like tieing in the side profile to match fender opening. Sure is a pin to get a good mounting point with a 3" BL.
Im def debating hard on a narrowed 44 swap due to hating the bushing wear on that damn front ttb and alignments
Big pics for the lazy lol
gearhead51
Fitzwilliam, NH
bumper gets my vote for being sweet, do the 44
SAY789
6
Springfield Or
5.8L
Hmmm..... what to do
SAY789
6
Springfield Or
5.8L
Man that faq. has good info on narrowing a 44, but it just doesnt tap off with a hammer lol
SAY789
6
Springfield Or
5.8L
Well a lil progress so far.
Got her narrowed and it took alot of cleaning but she looks decent now.
Grabbed a set of 4 wheels off C list for 60 bucks just so i can get this thing closer to go. And if i wouldnt of narrowed the axle i coulda used these wheels and still be at the same width.They are 15X7 3.5" BS
So im debating of upgrading my 8.8 to 4.88 and some sort of locker or just throwing a 9" in there and use these wheels to stay the same width i am now. I just need to research my 8.8 a lil more to see if i need a new carrier seein as i have a L/S 3.73 28 spline.
Here shes all cleaned up almost all assembled
Heres when i bolted the 15x7 wheels on the EB width axle
68.5" to outside of wheel to outside of wheel
My Dana 35 right now with 15x10 3" BS sits at 73.5" outside of rim to outside of rim.
If i would have left her full width, id be only an inch wider than now.
Im thinking about dropping some coin now on the gears for the axle but id rather get the rear done and geared first seein as its gonna be 2wd for a while might as well enjoy gearing.
