My 2000 Ranger build
Doug Metheny
Kentland, Indiana
hello guys i am going to start a build for my ranger with light im sure u have seen my post on here muilt times i apolligzie for that i didnt relize i was on this forum i thought i was on diffrent ones.
i am running 36 leds lights 11 down each side of the truck 4 to 6 inchs apart then on the back fo the cab on the left and right sid eof the rear slideing window i am putting 2 lights then i am adding 4 red lights to the bumper or the tail gate to work for turn singel and brake
then i want to do my dash insturments and hvac in blue or the uv blacklight color from superbrightleds
i am going to mount my 4 toggles on a peice of metal painted black in the cubby under my headunit i am installing 3 blue light up toggles for the body and 1 green for cab light
i want to install new bucket seat and a center counsole but not for sure what ones to get
then i have to fix the driver side door handle it is broke
then the last thing i have planed is ru 2.5in pipe to a flowmaster org 40 si/do then put 2.5in up in the bend and slide stacks over it like unattached tip and mabey put glasspacks or cherrybombs on the end of the exhaust under the stack
dash lights
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/specs/WLED-x4.htm
cab lights
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/specs/mbc.htm
clearnce lights
http://www.optronicsinc.com/oempages/mcl19.htm
clear with amber
clear with red
now my question is i was about to place my order for the dash light and there is an option for 32 degree angle and 90 degree what one is for the 2000 ford ranger with no tach and how many lights will i need? i was told 16
here is some picture before i start my work
i ordered today so the shipments should go out monday and be here around thursday
any ideas or suggestions and such is wanted
kris97ranger
36
lisle ontario
4 litre and 7.3 litre
do you already have the ones down the sides hooked up? if so do you have a night pic
________
Glass pipe
Doug Metheny
Kentland, Indiana
no i orderd them today i hope they get here soon and put them on for all of you to see
camodown
man it is really hard to read what you are saying.
But we need some night shots
Doug Metheny
Kentland, Indiana
i will try and fix the typeing sorry guys and once its done i will post some nice night pictures but i have a question for you guys should i keep the led lights for turn single and brake on the bumper like planed or put on tailgate
edit: i fixed post should be read able now
Doug Metheny
Kentland, Indiana
now that i do some more reading see since im running 11 leds on each side each of them light needs a resistors so each side needs 11 resistors then the back 4 on the bumper need some then the 4 behind the cab need some and then the 5 cab lights need some
but i cant seem to find any where to buy all these for the sides the chart says i need 1/2W resistors but i cant find the darn things any where and then i got to by me some inline fuses im goign to run the lights to the fusebox
all the lights should be here thursday morning and i plan to have them ran by sunday for all you to see
bcost882
5
The Queens Country.....
3.0L, 1.6L
is that an exhaust stack and a tailpipe i see??
pfrye2007
3.0 l
Did you try radio shack? They have resistors and also if you were in your shop class, If your school has a votec and there is an electronics class they should be able to hook you up. I was in EET electronics engineering tech in votech and we had millions of resistors sitting around all the time LOL. Hope one of these works for ya :headbang: can't wait to see night pics :icon_thumby:
Doug Metheny
Kentland, Indiana
ya i got a school that is not even 1a but we are in that class my high school has less than 300 kids way less so i only have ag mechanics 1 and 2 and then ceritifed welding and iv tried adding up my stuff to get the right reisitors but it doesnt sound right mabey one of you can get it ill supply the link and the information for the products
caculator
http://led.linear1.org/led.wiz
clearnce in amber
.080mA/12.8V i am running 11 of them lights in a straight line down the truck
then 4 clearnce lights in red on the back hooked to turn and brake
.080mA/12.8V
then cab lights in amber 5 lights on top of cab 3 in middle and 2 on each side
Current Draw: 0.150Amp (150ma) @ 13.5 VDC
i am running a normal automobile battery witch is 12.8volt source
if u guys come up with a right way and mabey understand this more than i do please share you thoughts and results.
ps. my auto classs teacher is kind of a dummy n doesnt know anything about leds only thing he know is wireing houses witch blows my mind that he doesnt understand ristors and such so im kind of off on my own doing thing
and links to the products are on my top post
Doug Metheny
Kentland, Indiana
well thank you very much you just made my day after a long day of track practice.
now its all i have to do is figure out this darn reistor stuff and it will be alot better
and i picked that stack up for 10 bucks
kris97ranger
36
lisle ontario
Doug Metheny
Kentland, Indiana
i know and i was told the stack is worth 45-50 bucks so i was happy
but guys this is what i have figued out for what i need
4 lights on back of cab and 4 lights on back of bumper or tailgate for brake and turn at 0.080ma
2x 100 ohm 1W 5% Metal-Oxide Film Resistor (2-Pack)
Item#: 2062295
5 cabs lights amber at 150ma
1x 22K Ohm 1/4-Watt Carbon Film Resistor (5-Pack)
Item#: 2062348
22 clearences lights 11 down each side=22. at 0.080ma
6x 150 ohm 1/2W 5% Carbon Film Resistor pk/5
Item#: 2062316
am i correct guys?
i am ordering when this is approved or fixed
from radioshack.com
I'm thinking side pipes for mine.
