- Nov 13, 2018
- 4,467
- Canaan,NH
- Ford Ranger
- Engine Type
- V8
- Engine Size
- 351
- 2WD / 4WD
- 2WD
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
No,I'm not going to lecture again about calling Supercabs "extended cabs" or traction lok's "posi's" though it's still happening.
Saying it doesn't run, shift, stop, or work properly won't help anyone diagnose a problem. There are people here who will try to help you given a chance and enough info.
I used to insist my service advisors ask the customers questions that would give the techs useful information:
"Hesitating" means that there is a delay between throttle movement and rpm increase
"skipping or missing" mean that the engine shudders or shakes and is usually more noticeable when the engine is under load
"surging" is when the rpms vary and is often noticed at idle and when trying to maintain a steady low speed
What driving conditions make the problem worse or more severe? High speeds? Low speeds? Uphill? on turns? On bumps? Engine warm or cold? Outside temp? Accelerating?
Are there driving conditions that make the problem less noticeable?
How long has the problem existed and did it happen all at once or gradually worsen?
