misfire at/around 3000 rpm
The Miracle
North Georgia
2.9 4X4
I posed this on a different ranger forum, fixed some other issues based on the replies(Thx, RonD) but not the main issue, so perhaps I can get some fresh eyes on the problem
It is a misfire or intermittent lack of fire around 3000 rpm. The tach drops when it happens.
I have replaced Coil, Fuel pump, FPR, plugs, wires, cap, rotor, TFI, pickup coil, and TPS
I have not replaced the MAP or O2 sensor.
No check engine light or codes present.
It ran ok last year, with the above problem every so often, but after sitting over the winter it does it constantly.
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
Compression test? Vacuum Leak?
The Miracle
North Georgia
2.9 4X4
I fixed all the Vac leaks, but it ran fine with a bunch of vacuum leaks last year.
Cant test compression but I think its probably fine, not usually something that suddenly changes I would think. Truck ran strong last year, no oil burning or blow by, and got 21mpg on the highway on a long trip despite being loaded down with a bunch of cargo and it being the 4WD model. Only has 120k on it even though it looks like total garbage.
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
Does the fuel pressure drop under load?
does the issue occur if you rev the engine to higher rpm or only while you Are driving?
The Miracle
North Georgia
2.9 4X4
Fuel pressure is where it should be according to the gauge I have, just in case I made sure to replace the fuel delivery system and the numbers really didn't change. It will misfire under no load as well. Its harder to tell but definitely does it. I can entertain the idea that this maybe a computer issue.
I have verified continuity from every pin of the computer harness to each input and output module(sensors, injectors)
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
I would hook up vacuum gauge and see if there is a dip in the vacuum at rpm. This could indicate an issue with the timing or valve train.
The Miracle
North Georgia
2.9 4X4
I can try that tomorrow. I wasn't thinking it was valvetrain as the tach quickly jumps around when it screws up, which made me think the spark was dropping out as the tach is run directly off the coil.
EDIT my apologies, the tach is run off of the TFI, the tach and coil trigger share the same signal
saxtech
37
Huntington Beach, California
Ford Ranger XLT
3.0 Flex Fuel
The Miracle
North Georgia
2.9 4X4
To the Original Poster - Did you ever find a fix for your misfire problem. I have a 2003 3.0 FF and I have a misfire under hard acceleration and over 3000 RPM. I found this Technical Service Bulletin but am dreading taking it to a dealer. What did you do? https://www.therangerstation.com/forums/index.php?threads/3-0-miss-stumble-out-of-ideas-and-money.49116/
The computer went out again. Pip signal into the computer was nice square wave but the spark out was pure shredded noise.
kyle1468
south carolina
I am having similar issue can you explain how I can go about testing the pip signal to computer and how I can test the signal from the computer newer to the electrical side of things but if you could just let me know easiest way to test that to see if my new computer is junk I’d appreciate it.
Josh B
1,986
Oklahoma
Hey Kyle, It may take a bit but you'll get the answers in time
Good luck with it
