sarcastic_cook
- May 4, 2013
- 0
- Mazda
Hello everyone,
I am new to the forum and have been poking around on here for a while trying to come up with something to match my issue. With no luck and tired eyes I am posting for some advice.
I have an 02 B2300 2wd that I bought about 6 years ago. One year in and the 3:73 rear end went out. I put in a 4:10 from a 99 ranger that is so much better. In the last couple years or so it has started having front end problems. Vibration in the steering wheel and floor board. Got my tires rotated/balanced, put in new shocks with no change. So then I moved on to new inner/outer tie rods, front bearings and alignment. That seemed to help for a while. About that time I got some almost new tires(less than 500 miles on them). After a while the vibration came back. On top of that it was time to make a 1000 mile move w/trailer. I decided to go with new bearings, brakes, drums and ROTORS all the way around including upper control arms, lower ball joints and sway bar bushings(old bearings looked to be in good shape). That brought about another issue. The rotors listed at the store had a diameter to small for the caliper and spindle. We looked at other years and models on the computer and found that the (I think it was) 03 ranger ran a larger rotor. I took them home to find a perfect match(I figure it was probably in an accident or something). Again the bearing change helped. Then I moved. Soon once again it started, but this time I get a pop in the steering every now and again usually in a parking lot making a turn. I decided to pack the bearings and see if that helped. When I cleaned off the spindles it looked like they are wearing about where the bearings sit. Same story. A month or so later during an oil change I decided to wiggle the wheels. It seemed like the bearings were loose so I reset the adjustment. Same problem, even worse now. Feels like the tires are going to fall off if they don't wear out first. The only front end related items that have not been replaced are lower control arm bushings, rack & pinion and the spindles. I want to replace the bearings and spindles but I have hit a wall. I have been looking for replacement spindles checking fitments and stuff. Because my rotors are bigger than stock and all the used spindles I have looked are interchangeable between the years I'm just not sure. Are all the spindles between years the same and the calipers bigger/longer or vise versa. I have tried to include as much info as possible. Any advice, help or info would be greatly appreciated.
Thank you in advance for any help.
