Manual Warn hub swap
clark89
Ottawa
2.3L
Ok so i currently have a 94 ranger with blown auto hubs, I want to swap out the autos for warn manuals, but i have a hybrid 35. Now instead of putting them on my hybrid i was thinking of just swapping my front axle out for a true Dana 35 from an explorer, but i was told the manual hubs wont work on an explorer Dana 35. I dont see why they wouldnt, everything is pretty much the same, im not to sure but i think the only difference is the hubs. Just want to know if this will work, and if so is it the same process as if i was putting them on my ranger axle.
O and just so i dont get any, why do you wana get rid of your hybrid questions, i want to be able to put on at least 33s maybe 35s some day.
Thanks in advance for any help.
scotts90ranger
4,447
Dayton Oregon
2.3 Turbo
the hubs are the same between the hybrid and true D35, the only difference is the pumpkin and the axle shafts going into it. so all you need from an explorer or whatever is the pumpkin and axle shafts, that'll save you from having to do an alignment...
clark89
Ottawa
2.3L
k i thought that they were the same but the dumbass at bensons told me that there was no way that it would work, i think hes new.
I have never swapped axle shafts or a pumpkin before, what would be easier, swapping out the whole front end or just the axles shafts.
Also just a thought, i want to upgrade to bigger 5-670x u-joints, and found a set of chromoly dana 35 outer, would these work with the new u-jonts so that all i have to modify is the internal shafts.
Nhaz
4
The Great White North, Ottawa, Canada
1998 and a few
Ranger+Ranger+E
4.0 3.0
Minor thread derail.
You found a bensons in Ottawa that is open? 2 years ago they build their stores and then closed them all!
clark89
Ottawa
2.3L
Theres one in Carleton place where i live, its about 20 min from ottawa, and less then 5 from my house. And even better i get a discount!
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
They should, yes. Be sure to get the (Warn) Jeep #37780 locking hubs if you're gonna go that route, otherwise you're wasting your $$$ (also, the 5-760x joint isn't bigger physically, it's just stronger).
Swapping the center chunk isn't that big of a deal, but I would take into consideration the condition of your axle vs. the one you're getting, and base your decision whether to swap just the chunk or the whole thing on that.
07rangerfx4lv2
Ontario, Can.
ford ranger
4.0l
im not a fan of the guy at bensons, told me to sell my ranger and buy a fullsized
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
The D35 "Hybred" already has the same joing as all "real" D35's and most D44's
The INNER shafts and diff are weaker than "the real thing", but frankly if your truck came from the factory with a "hybred" you don't have enough torque to break it anyway.
AD
clark89
Ottawa
2.3L
I know i dont have the torque to break my axles, thats not the reason im thinking of doing the swap. I would like to go with atleats 33s for now, and some day go with 35s, and i was told that a hybrid can handle 31s at most.
Nhaz
4
1998 and a few
Ranger+Ranger+E
4.0 3.0
Even the one in Almonte is closed! thats just up the road from you.
I think all the bright yellow siding they put up cost so much they had to close all but yours!
clark89
Ottawa
2.3L
I think there is a bensons in Arnprior to, its about 30-40 min from me, and where abouts was the one in almonte.
Nhaz
4
1998 and a few
Ranger+Ranger+E
4.0 3.0
If you are coming in from the 417 side its right past the new traffic circle on the left. Across the street from that silly mall they put up thats been mostly empty for the last 3 years.
And I am 20 minutes from Arnprior. I only make it into Arnprior on the weekends. and its always closed on the weekends.
