Cheburashka
- May 3, 2020
- 8
- Los Gatos CA
- 4.0 XLT
Good, only other hurdle is the Speed sensor issue
When you get the new/used transmission pull off the tail shaft housing and see if you can use your 1995 tailshaft speedo drive gear on it and of course your 1995 tail shaft housing if so
Worst case is you use an SGI-5E interface using the rear axle's ABS sensor, thats what Ford did in 1998-2000
Ok, so the transmission swap went fine. Thanks for all the help.
Do you know where under the hood I can grab the signal from the ABS sensor and where the speedo signal cable is?
