- Jun 2, 2012
- 8,416
- canada
- Ford
No, 12 to 24 gauge is fine, its only 1-2volt AC
I would test the VSS plug in wires, as you said 1 should show as Ground and the other as not a ground
Same for the grey/black wire you are splicing into, it should not show as a ground, test key off and key on
1995 to 1997 VSS wiring seen here: https://ww2-secure.justanswer.com/uploads/FO/fordguy4u/2013-05-22_172049_a1.jpg
So you can tap into, NOT CUT, any grey/black wire and it will feed all the devices with the GPS speed signal
