Limited slip diff
Tangoj
Houston, TX
Hey, I recently had my 98 Ranger's rear end rebuilt. How do I know/test that the limited slip is still working?
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
One tire on the pavement one on the grass. Nail it. Did both spin after a second or two?
Sometimes you need to preload it a little by applying a little brake to get a LS to catch, but if it's just been rebuilt, you shouldn't have to.
Best way is to jack it up so both rear wheels are off the ground, leave trans in N, and turn the wheels by hand, they should both spin in the same direction.
G8orFord's suggestion will work, but comes with the possibility of trenching your yard.
8,370
If you go to a gravel or dirt road and "step on it" you should see TWO tire spin marks, with OPEN differential just ONE
Tangoj
Houston, TX
Great! Thanks to you both. I'll try both options.
gw33gp
Ham Radio Operator
537
Costa Mesa, CA
4.0 SOHC
33"
Ford's technique is to lift one tire off of the ground, put the transmission in neutral and measure the torque required to rotate the tire that is off of the ground. I don't recall the torque range that is considered good.
