I need to make a 90* gear box....
Ramcharger90
1,708
N/A na
306, Bcam,
So I am building the kid a mini T bucket and the only 2 ways I can think of is chain to a 90* gear box or a honda/ Toyota golf cart 2 speed trans. I want to use a 1947 crosley rear diff I scored so it looks like a T with a 9 inch rear as much as possible. So naturally the diff will be use to move the mini T bucket. I could make a 90* box using a very small diff cut down to act as a trans and use a drive shaft to the gear with a custom shaft. Or use that golf cart trans I found that inputs power to the front from the engine which creates a clutch issue...... any Ideas on small diffs?
60206
17,838
SW Iowa
D28 shouldn't be hard to turn up for cheap, cut out the beam for a cover...
8,370
Not quite following the build
Will the engine be a Briggs & Stratton type with centrifugal clutch or will there be a transmission with Reverse
There are several 90deg power takeoffs available
Google: 90 degree pto gearbox
Mower attachments for Tractors often had these on the decks
Bird76Mojo
1,265
IL
Scour Ebay for cheap used lawn tractor/mower gear cases. Snapper, MTD, JC Penney, White, Sears, Murray, etc.. There should be some cheap older boxes on there to do exactly what you need. I know I've had a few over the years. Some went from belt to chain with the 90 degree output, and some were chain to chain. Some will also have a gear lever for multiple speeds. Rear engine riders had some creative boxes in them.
You should be able to find a free Peerless unit locally. People are always throwing away the old rear engine riders.
Example 1
17,838
SW Iowa
Those for a shredder will be huge, heavy and power hungry for what he is doing.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Search for someone parting out a shaft drive atv. You could use a front or rear diff from one of them.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
One of those can am viscolock front diffs would be perfect
