yugregnar
- May 28, 2012
- Reaction score
- 0
- Location
- Everett Wa
- Make / Model
- Ford
- Engine Size
- 4.0L SOHC
- Automatic
Ok i need help fast and correct i cleaned my maf, aic and throttle body on thursday. Now today all of a sudden my engine started sputtering and wont drive very well(keeps missing)??. I took it to oriellys and the comp said misfure at 1000rpm and also something with misfire 6 cylinder. It drove fine the last two days and even on the way to work today. When it starts up it is at 1000 then drops down to 500-750 on the tach. please let me know what to do. Im thinking i have fouled # 6 plug i did find a rub mark on wire 4 and i did use seafoam to clean throttle body, maf cleaner on the maf, and brake clean on aic. It us a 4.0 in my 2005 fx4. Please help as i need to drive it home from work tonight and its like 24 miles. Like i said this just happened to me, it drove great the day i cleaned everything and on the way to work today.. I forgot to tell you i am afraid to drive this home will i make it????? Dont want to overheat the engine. I did when I put in the seafoam for the throttlebody clean, the friggin tube was pointing down the air tube so I have seafoam in air box on the bottom under filter, not alot but some. So I am going to reclean the MAF,AIC,& not touch the throttlebody. Did I Foul the Plugs with the seafoam or what. I plan on changing the wires and plugs tomorrow as well.
