- Aug 31, 2021
- 974
- Roanoke VA
- 1997 and 1999
- XLT 4x4 & B3000
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L in XLT, 3.0L in B3000
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
I got Fram coolant 100% and distilled water and 195F thermostat and gasket. I think I'm ready to put in new gasket and new coolant. My question is about flushing. In my recollection, and it's been a while, I drained the old coolant, put in plain tap water, being careful to not put real cold water in hot engine, ran it until warm, drained it, maybe did that a couple times, then swapped out the thermostat and filled with good coolant, probably 60% coolant /40% water, I think that's what they say to use in the manual. Am I on target about that? Do you recommend any aftermarket flushing additives, or is that not necessary? I never used them before. Also, will I have to bleed air out of the heater core or bleed any high spots afterwards? Thanks.
